Lucario Runner's Supercharged going to Turbo JDM build.
Discussion in '2nd Gen. Builds (2005-2015)' started by Lucario Runner, Jan 1, 2018.
  1. Dec 21, 2019 at 10:10 AM
    #321
    Lucario Runner
    Lucario Runner [OP] Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Found me trailer. Good empty weight, trailer brakes, I can service it easily.
  2. Dec 21, 2019 at 11:16 AM
    #322
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Nice! A guy like you needs a trailer with as many vehicles as you have! Congrats!
    There’s a new project in my future that I will need a trailer for and it’s 10+ hours round trip to go get it. Hopefully the taco is up to the task.
    That trailer there is much bigger than I would need, though. This project only has 2 wheels :D
    Torspd and Lucario Runner[OP] like this.
  3. Dec 21, 2019 at 11:23 AM
    #323
    Lucario Runner
    Robert
    06 Toyota 4Runner
    It's a good tow. I was thinking about adding a winch and some race ramps. @Torspd mighy need to add his handiwork in installing colorshifts. Lol. I can tell the supercharger will make light work of this. I plan on maybe February or summer for that to be installed. Two wheels can I predict a bicentennial motorcycle? ;)
    Torspd and loginfailed[QUOTED] like this.
  4. Dec 21, 2019 at 11:45 AM
    #324
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Definitely need a winch that would make it easy to load vehicles on there for sure. Si, una motocicleta. A very generous friend is hooking me up big time.
  5. Dec 21, 2019 at 11:54 AM
    #325
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Ah, good deal. Always great when u get the hookups.
    loginfailed[QUOTED] likes this.
  6. Dec 23, 2019 at 7:13 AM
    #326
    ChadsPride
    Sponsored by TacomaWorld.com
    Happy Bday! :cheers:
    jojotoo and Lucario Runner[OP] like this.
  7. Dec 23, 2019 at 7:52 AM
    #327
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Thanks mate!
    ChadsPride likes this.
  8. Dec 23, 2019 at 7:53 AM
    #328
    ChadsPride
    Hope it's a great one :proposetoast:
  9. Dec 27, 2019 at 3:31 AM
    #329
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Belated, but happy birthday dude!
    I picked up my little wagon. Had to do some wiring clean up, but it’s a pretty solid little trailer. Had to order a 12” drop hitch to get the nose level. *Lifted taco problems*
  10. Dec 27, 2019 at 9:21 AM
    #330
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yeah ive been looking at bumpers and most are tucked up high like part of where the license plate goes and most are non rated in terms of class for the rating. Ive only found one I think its the 4x bumper so more than likely I'll end up with that bumper. Plus in my case I'm not really lifted so the angle isnt exacerbated as much.
    loginfailed likes this.
  11. Dec 27, 2019 at 10:38 AM
    #331
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    On mine the receiver is behind the flip up license plate. It isn’t rated either, but I’ve had no issues with light towing.
    You’ll be moving cars, so I could understand looking for a bumper with a legit tow rating.
    Torspd likes this.
  12. Dec 28, 2019 at 8:47 PM
    #332
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Picking away little by little. I took part of a harbor freight motorcycle chock and bolted to the front. I have the e-track sections cut to length. Just need to drill some holes and bolt them on and it’ll be ready for moto transport.
  13. Dec 28, 2019 at 9:24 PM
    #333
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Looking good.
  14. Dec 29, 2019 at 6:16 AM
    #334
    Lucario Runner
    Robert
    06 Toyota 4Runner
    My friend has the hookup on warn winches so I might look at picking up a winch 1.5 times as to what the trailer is rated for. Incase you need to drag something and don't want to burn out the motor. As far as lighting I was thinking of runway style led strips to help in lining up the vehicle on the trailer. Either make a cubby for race ramps or just have them in the bed of the truck. That's all i got as far as planning what to do to the trailer. Also ima sticker bomb the shit outta da trailer 4 max jdm points, water seal the planks, and plasti dip the trailer wheels for max tw points.
  15. Dec 29, 2019 at 6:45 AM
    #335
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Snatch blocks can help increase your winch capacity so that you don’t have to get too crazy with winch size.
    I was thinking that in addition to LEDs and sticker bombing, it would get me extra points if I match the wheels on the trailer to the ones on the Taco.
  16. Dec 29, 2019 at 9:58 AM
    #336
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It should be parked indoors most of the time. But just in case, the decking is getting a coat of Thompson’s Weatherseal for a little protection.
    Dookie brown, FTW.
  17. Dec 31, 2019 at 8:57 AM
    #337
    Lucario Runner
    Robert
    06 Toyota 4Runner
    New goodness
    05Taco4x4 and mightytacoman like this.
  18. Dec 31, 2019 at 9:11 AM
    #338
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I havent done that yet was gonna wait till the weekend to treat the planks. My trailer will be outside. I was planning on adding a horseshoe driveway with a slot for the trailer/another car. I was gonna see if they make trailer covers but might not cause the shape might change with a tire/tool rack.
  19. Dec 31, 2019 at 10:04 AM
    #339
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    HF has a coupon today for 25% off. I’m going to snag one of those tool boxes to mount to the trailer tongue area.
  20. Dec 31, 2019 at 11:24 AM
    #340
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Where did you pick that little guy up? I'd like a new one myself
