Lucario Runner's Supercharged going to Turbo JDM build.
Discussion in '2nd Gen. Builds (2005-2015)' started by Lucario Runner, Jan 1, 2018.
  1. Jan 23, 2020 at 6:34 PM
    #361
    Lucario Runner
    Lucario Runner [OP] Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Anymore and it would blind people. But it does work with @Torspd approval. Example.
    RedLantern and TacoFMS[QUOTED] like this.
  2. Jan 24, 2020 at 5:47 AM
    #362
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Scotch guard needs to get that formula. What ever than tire shine is, it repels off road racing mud.
    05Taco4x4 likes this.
  3. Jan 26, 2020 at 5:04 PM
    #363
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Speaker install.
    ChadsPride likes this.
  4. Jan 26, 2020 at 5:45 PM
    #364
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    New speakers jam!
    Lucario Runner[OP] likes this.
  5. Jan 27, 2020 at 1:01 PM
    #365
    Lucario Runner
    Robert
    06 Toyota 4Runner
    New led 3rd brake light.
  6. Jan 27, 2020 at 7:15 PM
    #366
    ChadsPride
    Sponsored by TacomaWorld.com
    That's real nice
  7. Jan 28, 2020 at 7:19 AM
    #367
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @MESO did a great job with the tight tolerances of the molding. :thumbsup:
    MESO likes this.
  8. Feb 8, 2020 at 9:42 AM
    #368
    Lucario Runner
    Robert
    06 Toyota 4Runner
  9. Feb 8, 2020 at 3:28 PM
    #369
    Lucario Runner
    Robert
    06 Toyota 4Runner
    So my impressions under a dry rally.
    1. The track is harder on landings since the ground isn't wet.
    2. Front suspension is now the weak point. Either the front needs to come up a clip and/or a 650 spring or upgrade to elka/fox/king coilover. With my plans of a supercharger (60lbs wet or dry?) and a 75lbs front bumper it'll need attention as will as control arms like a camburg ball joint uca and superpro lca.
    3.e brake light is on. Idk why but @Torspd and I will figure out when we install the e brake back on the truck. It doesn't interfere in the drivablity of the truck.
    4. Rear hammer hangers w/cross tube, poly bushings, and add a leaf is awesome. The washout didnt make the truck step out and was way easier to control. Very happy with the rear setup.
    5. Truck pulls a little to the right now. Before I believe it pulled a tiny bit left. Idk if its a tie rod or the tabs got bent a bit. Maybe the spindle. I plan on getting a gusset kit for both the control arms and the spindle with the sway bar.
    It was a fun day. I'm working on uploading some vids I have.
    05Taco4x4, Torspd and tinker_troy like this.
  10. Feb 8, 2020 at 3:46 PM
    #370
    Lucario Runner
    Robert
    06 Toyota 4Runner
  11. Feb 8, 2020 at 7:14 PM
    #371
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A few good snap shots.
    IMG_20200208_150454033_BURST000_COVER_TOP.jpg IMG_20200208_144924675.jpg IMG_20200208_114001442.jpg IMG_20200208_113744420.jpg
    Something we could all use. :pccoffee:
    tinker_troy likes this.
  12. Feb 8, 2020 at 7:18 PM
    #372
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I place my bets on a cam bolt altering position.
    From how you described your first track day, all that I can add is this. The truck sticks when you want it, and breaks free when you tell it. It performed very well for nearly all stock-ish suspension.
    Be great to have some other guys with Tacoma's out there!
  13. Feb 8, 2020 at 7:30 PM
    #373
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Could be, haven't checked but it drives straight on the road, the zero is more right doe. lol. No probs doing texas highway speeds on way home.
  14. Feb 8, 2020 at 7:36 PM
    #374
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For all the others reading, my truck had the best ever mileage on the trip. Accounting for the tire size variance, I got 147 miles on a half tank, or 164.64 miles. With the aid of Sir Lucario Runner reworking my tune after my intake cams swap. Currently OEM intake cams, and Kelford exhaust cams. (Experimental purposes.)
    That's a major win.
  15. Feb 8, 2020 at 8:01 PM
    #375
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    After reviewing the videos, many are very shaky. :pout:
    The tape that I left over the speaker for the MSR track days, also greatly reduced the sound. Again :pout:
    I'll still upload them though. :thumbsup:
  16. Feb 8, 2020 at 8:06 PM
    #376
    Lucario Runner
    Robert
    06 Toyota 4Runner
    How bad could they be? lol
  17. Feb 10, 2020 at 6:40 PM
    #377
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Torspd, tinker_troy and ChadsPride like this.
  18. Feb 11, 2020 at 10:23 AM
    #378
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Time to upgrade those cam tab reinforcements!
  19. Feb 11, 2020 at 10:35 AM
    #379
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Already done. Just need some strong primer/paint then we can weld it up and go on bigger jumps.
  20. Feb 11, 2020 at 11:44 AM
    #380
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Springs ordered, or still debating?
