Lucario Runner's Supercharged going to Turbo JDM build.
Discussion in '2nd Gen. Builds (2005-2015)' started by Lucario Runner, Jan 1, 2018.
  1. Feb 19, 2021 at 2:27 PM
    #741
    Lucario Runner
    Lucario Runner [OP] Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  2. Feb 19, 2021 at 3:29 PM
    #742
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Gonna try it/them?
  3. Feb 19, 2021 at 4:43 PM
    #743
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Maybe. I'm hoping some aussies try it first and get decent results.
  4. Feb 20, 2021 at 5:28 AM
    #744
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They would be interesting to test. Easy enough to swap in. I know two perfect people to do that testing. State-side that is. Lucario Runner and JustDSM.
    Tim Stair in Aussie Land, is a thorough individual. It would be interesting to see what he comes up with as well.
    TodayWasTHeDaY likes this.
  5. Feb 21, 2021 at 3:07 AM
    #745
    Lucario Runner
    Robert
    06 Toyota 4Runner
    RedLantern likes this.
  6. Feb 21, 2021 at 6:56 AM
    #746
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Here are pics from hell in Texas. Truck did great and I somehow lived. Idk how northern folks do it.
    First the garage door broke. I fixed it before it snowed.
    This crap.
    By this point power went out/was out. I got called into work.
    Ugh.
    After work. Tried to take pic of the depth, didn't warm up much.
    Kicked these of the Mudflap.
    Next day. Still no power.
    Found a working gas station w/93.
    These two...
    Found a place w/pizza.
    Idk heres a snow gauge of Thursday. Thursday night/ Friday morning is also when i got power back.
    I've only been in snow twice before, a forced school trip to Angel fire and a light snow in 2015? Never liked it and dont need to be in it but it was cool to see that the Tacoma can do well in conditions as bad as this. The driver mod is also the best mod as I also only driven in snow once but never ice luckily from my track experience everything was fine, even towed a 2 or 2.5 ton tandem axle generator. Tacoma towed it no problem. Now it needs to warm up so i can get back to modding and I'm going to make a winter list.
  7. Feb 21, 2021 at 7:49 AM
    #747
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Good you got through the shit storm alright. Your track experience would have played a huge part in winter driving. Knowing how a vehicle behaves is one of the biggest factors in safe winter driving. Also proper all season or dedicated winter tires and throwing a bunch of weight over the back tires make a massive difference.
  8. Feb 21, 2021 at 8:50 AM
    #748
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yes it was quite the life experience to say the least. lol. I can do 110 days all day long but under 60? thats gonna be a no from me dawg. @Torspd can attest. But I'm making a list to be much better prepared. One trick I didn't know was putting silicon lube in the door lock and the door seal. So I ordered a can, I'm looking at these cheap diesel heaters on Amazon/ebay for the garage.
    https://www.youtube.com/watch?v=1dunxPZMQXs&list=LL&index=5&t=372s
    Looking at a much larger stand by generator. I wanted solar panels (still do) but maybe add a battery backup too?
    https://www.popularmechanics.com/home/a34059872/best-home-standby-generators/
    Gonna install a fireplace now with a pizza over. ;)
    Looking at russain mre, cold stuff. More milwaukee batteries and headed jacket, lighters, candles, indoor kerosene, and some other off the grid things. When I redo my driveway and add a horseshoe driveway add heating elements and in the floors in the house. Still unpacking and planning. For the mods I think I'll add a remote start to my truck. My mom also wants to do a couple of things to her rav4 adventure to do better in low traction conditions as well.
  9. Feb 21, 2021 at 9:27 AM
    #749
    TodayWasTHeDaY
    Russ
    Calgary
    Big plans, your gonna be prepared next time! It's smart to do and a lot of people never think of worst case scenarios. Candles, blankets, spare warm clothes, a shovel and some traction aids (sand, salt, traction boards) and a tow strap are good ideas for winter travel
    Pizza oven fireplace would be tits! I haven't experienced car doors and locks freezing up too often but it does happen at times so I never do anything for doors and locks except struggle when it does happen lol. You guys probably get that coastal humidity that would make that worse. Where I'm living now the power grid rarely goes down and when it does its only for a couple hours. Where I grew up it was on the outskirts of a smaller town so power outages happened more often but even then we never dealt with generators or anything. Worst power outage was only a day or so.
    Remote start and seat heaters are really nice to have when you deal with winter weather.
    I've got a couple shitty electric heaters in my garage right now and am going to drop my trans soon to remove a crapped out hydraulic throwout bearing, probably going to still be warmly dressed when doing the work.
  10. Feb 21, 2021 at 9:49 AM
    #750
    Lucario Runner
    Robert
    06 Toyota 4Runner
  11. Feb 21, 2021 at 9:51 AM
    #751
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yea the humidity plays a factor here. Like after I would drive the stuff would freeze.
    And the details on the battery.
    loginfailed likes this.
  12. Feb 21, 2021 at 9:52 AM
    #752
    TodayWasTHeDaY
    Russ
    Calgary
    Nasty. That would make for treacherous driving
  13. Feb 21, 2021 at 5:25 PM
    #753
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Glad you're okay! The diesel heaters usually give off a bit of a smell. Way easier and more convenient to get various propane heaters and keep extra grill tanks or little map gas torch size tanks around since you'll likely have some anyways. Or along the same line if you really wanna go hard you can get a big 100gallon tank on the side of the house like you would for a propane stove and plumb in a big heater in the top corner of the garage as well. Imo you're lucky they didn't spread a shit ton of salt on the roads like they do up here, melts the snow away sorta but makes you go from sliding to grip randomly for a while until it all melts. Way more predictable with just snow as long as you have the driving skills and good tires
  14. Feb 21, 2021 at 5:36 PM
    #754
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
  15. Feb 21, 2021 at 6:30 PM
    #755
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Ah yes I overlooked propane. I might look at those for like the camping gear. I think these coopers really handled the snow and ice well. I wasnt slipping and sliding where other cars and trucks were. Lsd and some more weight in the back would've been awesome too.
    not_nick[QUOTED] likes this.
  16. Feb 21, 2021 at 6:31 PM
    #756
    Lucario Runner
    Robert
    06 Toyota 4Runner
    yep, awesome wheels!
  17. Feb 22, 2021 at 8:28 AM
    #757
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That experience is invaluable.
  18. Feb 22, 2021 at 8:33 AM
    #758
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That was only one year ago. Very intrigued.
  19. Feb 22, 2021 at 8:46 AM
    #759
    Lucario Runner
    Robert
    06 Toyota 4Runner
    If you ignore it long enough either it'll correct itself or the light burned out. Lol
  20. Feb 22, 2021 at 8:50 AM
    #760
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Taking donations. ;) Also looking for a snout cutter if anyone has one they wanna sell.
