Lucario Runner's Supercharged going to Turbo JDM build.
Discussion in '2nd Gen. Builds (2005-2015)' started by Lucario Runner, Jan 1, 2018.
  1. Mar 3, 2023 at 12:58 PM
    #1401
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Sheeeeeeeit i’m rather familiar with the limiter, and i aint talkin bout the rev limiter :spy:
    or at least I used to be. Fuel is expensive now :rofl:
  2. Mar 3, 2023 at 3:28 PM
    #1402
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    The general design of the 05-11 grill is flawed. To plastic weld the inner and outer grill surrounds together at a point on the vehicle that receives the most stress is just ridiculous. Fortunately, Toyota rectifies this with the 2012 redesign. Doesn't help all those with the 05-11 model though. :(
    AR15xAR10 and Torspd like this.
  3. Mar 3, 2023 at 3:33 PM
    #1403
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    My 2011 honeycomb grille has held up just fine over the years. Don’t crest 100+mph often though.
    AR15xAR10 likes this.
  4. Mar 9, 2023 at 1:18 PM
    #1404
    Lucario Runner
    Lucario Runner [OP] Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Got my aem gauge for fuel pressure. Just waiting on the faces to be delivered.
    AR15xAR10 and HomerTaco like this.
  5. Mar 9, 2023 at 2:10 PM
    #1405
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Nice!
    I've got a boost gauge for the BRZ I need to find the time to install... :oops:
  6. Mar 9, 2023 at 2:47 PM
    #1406
    Lucario Runner
    Robert
    06 Toyota 4Runner
    It's a good tool to have. So me how much gas I use. Lol
  7. Mar 10, 2023 at 12:50 PM
    #1407
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Fuel rail tap in.
  8. Mar 10, 2023 at 5:18 PM
    #1408
    AR15xAR10
    Yeah ainnowayin hell i’m front end swapping. I dont like the 12-15 that much. Lol
  9. Mar 11, 2023 at 4:20 AM
    #1409
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @HomerTaco , which boost form are you using on the BRZ?
  10. Mar 11, 2023 at 4:22 AM
    #1410
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Lucario Runner , starting to look like we'll need to add in a terminal strip for all of these power and ground sources.
  11. Mar 11, 2023 at 6:14 AM
    #1411
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    He haz turbo....
  12. Mar 11, 2023 at 11:22 AM
    #1412
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Like off the battery or separate from it? I can order that SDHQ terminals. If my pump is the issue I'm looking at the hellcat walbro pump to replace and add in that harness upgrade.
  13. Mar 11, 2023 at 3:04 PM
    #1413
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Did a thing.
    HomerTaco likes this.
  14. Mar 11, 2023 at 5:38 PM
    #1414
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Speed by Design (SBD) turbo w/ UEL Headers, catless straight pipe and Perrin 3" dual exhaust - bitch is loud.
    Torspd[QUOTED] likes this.
  15. Mar 11, 2023 at 5:51 PM
    #1415
    TacoFMS
    Justin
    Louisa County, VA
    You have a perrin 3"!!! Super jealous now! IMHO that is the absolute best exhaust for those cars.
  16. Mar 11, 2023 at 5:54 PM
    #1416
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I got lucky. Dude that built this did everything right with the exception of the el cheapo ebay smoked tail lights. I'll swap them out for valenti's eventually. :D
    TacoFMS[QUOTED] likes this.
  17. Mar 11, 2023 at 6:09 PM
    #1417
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Torspd and HomerTaco[QUOTED] like this.
  18. Mar 11, 2023 at 6:50 PM
    #1418
    TacoFMS
    Justin
    Louisa County, VA
    The only exhaust that comes close is the hks... but it is less throaty and more tuner sounding. Not bad at all, but I like the boxer growl to be more prominent.
  19. Mar 12, 2023 at 11:12 AM
    #1419
    Lucario Runner
    Robert
    06 Toyota 4Runner
    HomerTaco and Torspd like this.
  20. Mar 12, 2023 at 12:01 PM
    #1420
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mmmmmmmmm! Has got to be even more a blast.
