Lucas Heavy Duty 80W-90 Gear Oil in transfer case?
Discussion in '1st Gen. Tacomas (1995-2004)' started by agalloch07, Dec 1, 2019.
  1. Dec 1, 2019 at 6:04 PM
    agalloch07
    agalloch07 [OP] Well-Known Member
    Anyone used Lucas Heavy Duty 80W-90 Gear Oil in the transfer case? I know the weight is a little off but i am more worried about the syncros than the wight issue. What aftermarket oil do you guys run in the transfer case?
  2. Dec 1, 2019 at 6:06 PM
    Bishop84
    Bishop84 Well-Known Member
    What climate are you in? Do you tow or offroad?
    We stick to 75w90 up here in Prairie Canada, I personally only run regular dino oil for light duty trucks.
  3. Dec 1, 2019 at 6:18 PM
    agalloch07
    I live in Indiana so cold in the winter and hot in the summer. And no i dont take this thing off-road much just use the 4wd if roads get bad
  4. Dec 1, 2019 at 8:17 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I run Lucas 80W-90 in my t-case, has been great. Don't forget that you can purchase a gallon for less than 4 individual quarts and save a bit of money. (Do the diffs at the same time.)
  5. Dec 1, 2019 at 9:36 PM
    agalloch07
    I bought 2 gallons hoping it would be enough to do my tacoma and 4runner. It looks like the front diff takes 1.15 quarts, the rear diff takes 2.75 quarts and the transfer case takes 1.1 quarts so hopefully 1 gallon is enough to do one truck.
    I always buy my gear oil from pep boys on ebay they have it for $25 a gallon and shipping is free if i buy 2 gallons. https://www.ebay.com/itm/Lucas-Oil-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
  6. Dec 1, 2019 at 9:39 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I always need more than 1 gallon to do all three...but you can do one truck and see how much you have left. Then, if you're going to need a third gallon, just wait to do the second truck :).
    Also, don't forget that you'll need a pump to get the oil out of the gallon jug and into the various cases. (or a funnel in the case of the rear diff)
  7. Dec 2, 2019 at 1:12 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  8. Dec 2, 2019 at 3:43 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    turbodb likes this.
  9. Dec 2, 2019 at 3:47 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I run Mobil1 75-90 in the transfer case and both diffs.
  10. Dec 2, 2019 at 3:58 PM
    OneWheelPeel
    Phoenix, AZ
    I'm way too young to be posting often though. Median age on that site is 60+ bickering about how horrible ABS and power windows are.
    turbodb and cruiserguy[QUOTED] like this.
  11. Dec 2, 2019 at 4:02 PM
    rnish
    Tacoma 2nd gen
    Automatic transmissions, power steering and air conditioning, just a waste of power.
  12. Dec 2, 2019 at 4:06 PM
    cruiserguy
    Elijah
    SEKS
    Lmao you're too correct. I don't post there either. Too much info to just try to absorb there and then try to pass along to help others. Most folks though don't wanna know if/when they could do things better regarding oil or oil changes for some reason.....:stirthepot::D
    OneWheelPeel[QUOTED] likes this.
  13. Dec 2, 2019 at 4:06 PM
    cruiserguy
    Elijah
    SEKS
    Lololol
    Well I mean technically speaking.... It is:D
    OneWheelPeel likes this.
  14. Dec 2, 2019 at 4:36 PM
    agalloch07
    No but that makes me feel better about running Lucas in the transfer case and not some $20 a quart full synthetic.
    I changed out front, rear diffs and t-case today. It took a little over a gallon but it's done. My front drain plug was being a pain and i was using a 3/8" hex socket because i could not find my 10mm. I remember seeing a guy on here who stripped his so i was trying to be careful. I ended up giving it a few good whacks with a big hammer and it came loose really easy. I could not fit the gallon jug and the pump under the truck with stock tires. So i ended up recycling a sriracha bottle taking the twist top off and removing the little nub on the end that holds the twist top and using it to fill the t-case. It worked really well and was much faster than them pumps that take forever. The front diff was a pain though i had to use the pump.
  15. Dec 2, 2019 at 4:47 PM
    OneWheelPeel
    Phoenix, AZ
    Our Toyotas actually like siracha sauce so you're all set.
  16. Dec 2, 2019 at 4:58 PM
    rnish
    Tacoma 2nd gen
    My truck was built in California; it prefers wasabi.
    cruiserguy likes this.
  17. Dec 2, 2019 at 5:04 PM
    OneWheelPeel
    Phoenix, AZ
    In before the royal purple guy gets here
