Lucas Oil for Lifter Tick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Apr 19, 2018.
  1. Apr 20, 2018 at 12:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Technically the bucket shims, are called "lifters." I don't like that designation as it causes confusion. Bucket shims is defineably more accurate, for conversation.
    It is extremely labor intensive to "adjust" the lash. If wear has loosened the tolerance.
  2. Apr 20, 2018 at 12:30 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Add down time to this . Measuring the gap then figuring out the shim you need for each piston then going to the dealer and getting raped for a handful of shims that look like quarters .:annoyed:
  3. Apr 20, 2018 at 12:36 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No quarters on these. Just a whole new bucket. Still the same downtime though, for sure. Yuck.
