Lucas Oil octane booster
Discussion in 'Performance and Tuning' started by US Marine, May 21, 2016.
  1. May 21, 2016 at 3:13 PM
    US Marine
    US Marine [OP] Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've got a spare bottle of Lucas Oils racing formula " not street legal " octane booster that I normally run in my 11.1:1 sbc . This octane booster contains MMT or manganese and why it's not street legal
    My question is since I've got a supercharged 2.7 4 cylinder would this octane booster help any especially since its running 4.5psi boost . Even with it saying that it won't harm catalytic converters with it having MMT harm the converter in any way , MMT additive will turn your spark plugs porcelain and ground strap a rusty brown color . So this may coat the converter the same way ?????
    Since its a racing formula would I see any benefits
  2. May 22, 2016 at 7:01 AM
    US Marine
    Chuck
    Gallatin Tennessee
    Anyone ..... ??????
  3. May 22, 2016 at 3:57 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    If you are running 91 or 93 octane and running only 4.5psi i dont see it helping you at all.
  4. May 23, 2016 at 11:22 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I don't know much about that additive......... but if you aren't experiencing any engine pinging or haven't increase ignition timing, then I doubt the additive will do much for you. The risk of adding the additive is fouling up your cat or O2 sensors etc
    Not sure it's worth the risk/reward benefit. But obviously, that's all up to you.
  5. May 23, 2016 at 11:54 AM
    US Marine
    Chuck
    Gallatin Tennessee
    I use both the NOS "race fuel not street legal" or the Lucas Oil "race fuel not street legal" octane boosters that also have MMT in my 11.1:1 sbc in my Camaro all the time . It barely runs on 91 octane with 40 deg total timing . The MMT in both leaves a rusty color on my plugs and both octane boosters increase octane 31 points
    I usually run VP C12 race fuel which is good up to 15.1:1 comp in my Camaro but when I don't I use those octane boosters
    Was just curious about trying some in my 2.7 4 cylinder in my 2002 Tacoma
  6. Jun 7, 2016 at 4:17 AM
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I used Octane booster in my truck every other fill up and then my truck started bogging out under load. After hours of going through everything I finally checked the plugs. When I took them out they were bright red. Come to find out the octane booster fowled my plugs. So I wouldn't use any octane booster if I was you.
