lucas oil stabalizer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rtilton12, Sep 15, 2022.
  1. Sep 15, 2022 at 5:06 PM
    rtilton12
    rtilton12 [OP] Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    anyone have any good reviews on this stuff? never used it before but gonna change the ol engine oil and add a qt in place of a quart of oil and see how it goes. Lucas oil stabilizer high mileage
  2. Sep 15, 2022 at 5:07 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Any particular problem you’re trying to solve?
    SR-71A and whatstcp like this.
  3. Sep 15, 2022 at 5:09 PM
    rtilton12
    Robert
    Texas
    im at 113k miles (just broken in, i know) but i was liking the feature of it keeping the cylinders and cylinder heads, etc, lubricated for dry starts.
  4. Sep 15, 2022 at 5:09 PM
    saint277
    saint277 Vigilo Confido
    No need, just keep up regular oil changes.
    Dm93, TheDevilYouLove, SR-71A and 2 others like this.
  5. Sep 15, 2022 at 5:18 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I use it to make up that half quart during oil changes.
    I have seen the effects of using the lucas in big rigs, half a million miles with very little wear on the mains.
  6. Sep 15, 2022 at 5:29 PM
    rtilton12
    Robert
    Texas
    smart. ill do that and have another half left over for the next oil change. thanks!
    sparkystaco[QUOTED] likes this.
  7. Sep 15, 2022 at 5:30 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Maybe would make sense if our engines had issues. But our engines are proven to go a long time with no issues. we’ll only the head gasket issues on early models. Besides that, flawless engine
    SR-71A, RA77 and rtilton12[OP] like this.
  8. Sep 15, 2022 at 5:32 PM
    rtilton12
    Robert
    Texas
    no argument there. just wondering if i can be of anymore assistance with helping wear later on at a cheap cost each oil change interval!
    RA77 and sparkystaco like this.
  9. Sep 15, 2022 at 5:35 PM
    saint277
    The problem with that stabilizer stuff is that it doesn't have the additive package your normal oil does, so swapping out a 1/2 quart waters the additive package down. The only thing it does is increase the cold viscosity of the oil. You are better off just using 10w-30 instead of 5w-30, you get the same viscosity increase but the oils additive package remains the same. Additive packages are very important in modern engines you shouldn't water it down.
  10. Sep 16, 2022 at 5:00 AM
    Shawner1974
    Shawner1974 Well-Known Member
    Shawn
    CNY
    2012 Base Tacoma 2.7. 5 spd Regular Cab
    I have used it with good results in transmissions, transfer cases, and differentials in older vehicles. Never thought about using it in an engine until my step daughter drove her Corolla several hundred miles with the oil 3 quarts low and the oil light flickering (she ain't the brightest). That engine had massive tick going on. I drained the 10w-30 and put in 3 quarts of 20w-50 and a full quart of Lucas. After about 5 seconds that engine was quiet...freaky quiet...purred like a kitten. That was 4 months ago. Still running good but definitely on borrowed time. As others have said, as long as you're not neglecting oil changes you will be just fine without Lucas. If you're trying to eke a few more miles out of an engine you might need it.
    rtilton12[OP] and Doc Samson like this.
  11. Sep 16, 2022 at 5:36 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    The oil control rings maybe stuck. You can try Amsoil power foam and fill the cylinders. Berrymans B12 in the fuel may unstick those rings. Check the PCV as well.
  12. Sep 16, 2022 at 8:51 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    dont put the lucas shit in your truck (or any "high mileage oil" for that matter).... keep doing regular 5k mile oil chances with standard non high mileage 5w-30 of your choice (conventional, syn blend, full syn) and a fresh filter, the engine will last for 300k EASY by sticking with that
  13. Sep 16, 2022 at 10:19 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you need to run oil stabilizer, you already have a problem. And stabilizer isn’t going to fix it.
    I’d save your money and apply the savings to other maintenance cost.
    rtilton12[OP] and SR-71A like this.
  14. Sep 16, 2022 at 10:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    And what is your before and after method to measure 'how it goes'?
    If you don't have one, you're just guessing.
    TnShooter likes this.
  15. Sep 16, 2022 at 11:50 AM
    vtdog
    vtdog Well-Known Member
    NH
    Unless you want to help Mr. Lucas pay for his kids college tuition don't buy
  16. Sep 16, 2022 at 11:57 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Installing an accumulator would do more for cold starts than the additives imho
  17. Sep 17, 2022 at 12:31 AM
    TacoTuesday1
    FL
    I personally do cheap 3-5k mi OCI with high quality synthetic oil and my metal looked new, discolored, not stained, not varnished, and clean enough to eat off of when I pulled the valve covers at 150k
    but you do what you want
    Dm93 likes this.
  18. Sep 17, 2022 at 4:18 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Do you need it, probably not. Will it hurt anything, probably not. Your choice, make your own decision.
    As you can see, there won't be any consensus here!
