Lucas oil stabilizer.
Discussion in '1st Gen. Tacomas (1995-2004)' started by J.A.92, Mar 4, 2019.
  1. Mar 4, 2019 at 9:46 PM
    J.A.92
    J.A.92 [OP] 97 Tacoma 4x4 lx 5 speed manual.3.4L
    Juan
    1997 Tacoma 4x4 lx xtra cab.3.4
    so my uncle being nice washed my truck and changed my oil with a good synthetic oil.But for some reason added a Lucas oil stabilizer in.Should I be worried about running this in my motor for at least 3k miles? Or should I just drain that blend out and add a plain or synthetic?
  2. Mar 4, 2019 at 9:52 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Was it burning oil? What are the compression numbers for each cylinder? Most of the time oil additives are a waste of money because modern oils, especially synthetic, are very good. They may help in a last ditch effort to keep a worn out engine running a little longer.
  3. Mar 4, 2019 at 9:56 PM
    J.A.92
    Juan
    It might burn the smallest amount of oil.I'm not exactly sure compression numbers.But it's a clean 1 owner 3.4 with 170k on it.Ive been running it for about 2 weeks.But the more I think about it makes me wanna just change it.Will it fuck my motor up if I run it a few k? I've never even bought that stuff before.Nor know much about it.So made me a bit uncomfortable.So would like some feedback.Thanks!
  4. Mar 4, 2019 at 10:32 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I run 1qt of Lucas oil stabilizer and the rest Mobil1
    Have been doing so for around 230,000 miles. I don't think you have anything to worry about.
    Why would there be anything to worry about???
    Wyoming09 likes this.
  5. Mar 4, 2019 at 10:34 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    May not have been necessary but it won't hurt anything
    SilverBulletII likes this.
  6. Mar 5, 2019 at 2:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I used it all the time in my High Mileage 22RE engines .
    It won`t hurt anything
  7. Mar 5, 2019 at 3:45 AM
    Thad
    Thad Well-Known Member
    Thad
    Pittsburgh
    2004 Tacoma
    I use it religiously especially in gear boxes. I was always a sucker for the little gear thingy on the auto parts sales counter showing how it makes your oil cling.
    taco abbo, JGO and TS7xTaco like this.
  8. Mar 5, 2019 at 4:01 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Marketing is great, isn't it? :D
  9. Mar 5, 2019 at 4:15 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I use it every oil change on the boat and both my trucks
  10. Mar 5, 2019 at 4:57 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I’m torn on this, I have a slightly noisy lifter and was thinking this stuff might help but I haven’t looked into the synthetic compatibility, I know it’s fine for conventional...
  11. Mar 5, 2019 at 5:22 AM
    cruiserguy
    Elijah
    SEKS
    You must resist temptation.
    I'd be surprised if compatability with synthetic is an issue. But compatability with MY engine's oil? Nope, not compatible :)
    RysiuM likes this.
  12. Mar 5, 2019 at 5:25 AM
    Rachelsdaddy
    Southern NH
    I know I should, the engineers know what they need to put in the blend but that little ity bity tick is driving me nuts. Might try a thicker synthetic...
  13. Mar 5, 2019 at 5:33 AM
    cruiserguy
    Elijah
    SEKS
    I hear ya, isn't zinc the big cleaning agent in the oil formulated for diesel engines? Maybe try some Rotella 5w-40, the blue bottle stuff. That's very good oil.
    Or check what the folks at bobistheoilguy.com have to say. Best oil/grease site there is
  14. Mar 5, 2019 at 6:37 AM
    J.A.92
    Juan
    Thanks guys
  15. Mar 5, 2019 at 6:39 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    oh man - it's gonna blow up! Take it out NOW!
    J/k - it's fine. It's like adding gear oil to your engine. Helps keep oil in the higher part of your motor longer. Doesn't hurt anything. Could be snake oil. Usually they have all that stuff at the front counter of parts stores to trick people into thinking they need that stuff in their engine.
  16. Mar 5, 2019 at 6:46 AM
    J.A.92
    Juan
    Haha.Well I like to take care of the engine and I've never just poured that in so I was like hmm.Maybe I should research it and maybe get a second opinion.
  17. Mar 5, 2019 at 7:18 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Three points:
    1. Toyota does not put that stuff it in the new car
    2. Toyota does not list this stuff as a part of preventive maintenance
    3. The engine oil bottle (synthetic or conventional) does not have any writing saying you need to mix it with the oil
    so... why bother in the first place ? Any of these magic oil additives are at the best scenario just waste of money, at worse harming the engine preventing from proper lubrication or destroying rubber seals. Just my opinion.
  18. Mar 5, 2019 at 7:27 AM
    Xbeaus
    Beau
    Reminds of those things they used to sell where you put a magnet thing around your fuel line . They only sell them because it's proven that people blindly buy them. lol
  19. Mar 5, 2019 at 7:29 AM
    J.A.92
    Juan
    I didn't add it.My uncle did out of being kind.So i wondered whether I should drain it and put just oil in it.Or if it'll be fine for an oil change.
  20. Mar 5, 2019 at 7:48 AM
    Renogasser
    Renogasser Well-Known Member
    Scott
    Nevada
    2013 DB cab TRD Sport
    Level kit 32” Goodyear Duratracs
    No worries it’s not going to HURT anything this additive helps the oil cling to lubracated parts for extra protection
    LUCAS OILS are one of the best on the market, you’ll be fine till next oil change. Do your research till then and decide if you want to run an oil additive.
    J.A.92[OP] likes this.
