lucas oils response to gear lube question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mustangwilly, Jan 27, 2011.
  1. Jan 27, 2011 at 4:03 PM
    mustangwilly
    mustangwilly [OP] Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    I asked Lucas oils about adding friction modifiers to their dino 80/90 gear oil for a limited slip diff. This was their response ...what do you think?
    Our 80w/90 has a friction modifier package already in the formula. I would
    also use some of the Heavy Duty Oil Stabilizer in with the gear oil around
    10% of the capacity. The Oil Stabilizer will keep the oil climbing up the
    gear and keeping the oil temperature down in the differential.
  2. Jan 27, 2011 at 4:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Like the majority of the people with the mechanical LSD.... You can use whatever oil you want (recommended via manual) and it could already have the friction modifier in it....But until you put it in there and drive it around - chances are, you'll have to add more friction modifier especially if you run synthetics.
    It's a *wait and see what happens* kinda deal.
  3. Jan 27, 2011 at 4:10 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    There's a pretty long thread on here about the experiences people have had with various kinds (brands and syn/dino) of gear oils in their LSD. A good rule is to use dino with friction modifier. Although some have had success with synthetics, for most it's temporary and they end up chattering. I think one member was using Mobil 1 Delvac without issues. Can't remember if he added any friction modifier though. If I find the thread I'll post a link.
    Here it is:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/93117-beware-changing-lsd-lube.html
  4. Jan 27, 2011 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You dont need to use their bullshit "Oil Stabilizer" shit. The diffs have a device that ensures the gear teeth are lubed. All the oil stabilizer crap does is make the oil foam up, and cause poor lubrication.
  5. Jan 27, 2011 at 4:54 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    :thumbsup:
  6. Jan 27, 2011 at 4:54 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    LOL!!! Why don't ya tell us how you really feel?!(I agree)
