Lucas vs Super Tech Full Synthetic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Apr 9, 2019.
  1. Apr 9, 2019 at 3:31 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I am sure this has been covered, however, is Lucas worth double $$ Super Tech Full Synthetic Gear Lubricant 75W-90? I just did my front diff and transfer case this past weekend (used Lucas) and it really got me thinking, I should be doing the rear diff too. I'm just having a hard time with 14.00 a QT...but maybe it's worth it.
    What say the hive??
  2. Apr 9, 2019 at 3:44 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Plenty of opinions to come I am sure. Someone told me that the supertech comes out of the same tap as the name brands. I would run it with no issue as long as you keep up with the regular changes.
    Freeheelbillie[OP] likes this.
  3. Apr 9, 2019 at 4:07 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Nope I get the cheapest fluids in the proper viscosity. Mobil 1 has a rebate going on right now.
    TacomaMike37 likes this.
  4. Apr 9, 2019 at 4:15 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Supertech Synthetic motor oil is some decent stuff, there are some blackstone tests around to back that up. I would have no reservations about using their other stuff on my truck and I also use their tractor oil. If I can’t get M1 on the cheap I use Supertech.
    i would however not use anything but Lucas in my front Diff as I have the ECGS bushing and the Lucas is recommended. It has anti foaming additives to keep the bushing properly lubricated.
  5. Apr 9, 2019 at 4:24 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I had no idea it was Lucas was recommended for the ECGS Bushing, which I also installed this weekend. Got lucky on that one! :pray:
  6. Apr 9, 2019 at 4:41 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  7. Apr 9, 2019 at 4:58 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I use supertech. No issues.
    TacomaSport86 likes this.
  8. Apr 9, 2019 at 5:02 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I use Lucas dino oil, 80W-90. Costs a little over $6 a quart on sale and shipped to my door from Advance Auto. SuperTech isn't a whole lot cheaper. Got it in both diffs and the xfer case.
  9. Apr 9, 2019 at 7:31 AM
    USMCtaco88
    USMCtaco88 Common sense isn't always a common trait
    My names Jeff
    Savannah, Georgia
    2015 Silver Sky DCSB TRD OR
    I did some stuff.
    I did my last diff / transfer case fluid change with nothing but Supertech full synthetic. that was around 25,000 miles ago and I'll be using them again when its time for another change. zero issues
  10. Apr 9, 2019 at 8:00 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Super Tech for me......buy it online...3 packs of 5 qts
    $16 a jug....free shipping....no oil recycle fee either as in store !
  11. Apr 9, 2019 at 8:01 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
  12. Apr 9, 2019 at 8:23 AM
    Armed in Utah
    2003 Lexus LX 470
    sorry......coffee hadn't kicked in yet.......
    gear oil......not motor oil.....:crapstorm:
  13. Apr 9, 2019 at 9:31 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Neither,get Mobil 1
  14. Apr 9, 2019 at 9:37 AM
    jandrews
    '09 FourDubDee TRD OR
    It's all certified stuff. FWIW conventional dino gear oil generally keeps the metallic components of the gear assembly cooler. ECGS recommends Lucas conventional 85-140 and that's what I run. I doubt it much matters what brand you use.
    ajm likes this.
  15. Apr 9, 2019 at 9:39 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Mobil 1 75-90; $6 and change per quart when on sale at PepBoys.
