Lucus oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoOwner?, May 26, 2011.
  1. May 26, 2011 at 5:02 PM
    TacoOwner?
    TacoOwner? [OP] Well-Known Member
    Joshua
    Camas/Spokane, WA
    '10 4x4 Double Cab 6M
    Anti-thief tailgate, anytime rear-view camera, anytime locker mod
    Went to the store to get my oil and decided to pick up some of that Lucus oil stabilizer. The guy said I should put the entire bottle in then fill with regular oil. Anyone else use this product in engine oil or transfer case/transmission? How much do you use with engine oil? Notice any changes?
    Thanks for the help!
    Josh
  2. May 26, 2011 at 5:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    DO NOT use that stuff! Its junk!
  3. May 26, 2011 at 5:04 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    not needed
  4. May 26, 2011 at 5:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just a random review I found:
  5. May 26, 2011 at 7:37 PM
    TacoOwner?
    Joshua
    Camas/Spokane, WA
    Damn ok. I started wondering when I saw how thick it was, I fear of making the oil too thick that it can't get in the tightest of places needed. Which may be the reason that 350 had a problem. Older cars not so much since they are worn.
    Thanks for input!
    Josh
  6. May 26, 2011 at 7:50 PM
    TacoOwner?
    Joshua
    Camas/Spokane, WA
    Should I drain and refill?
  7. May 26, 2011 at 11:53 PM
    philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    - philo
    Venice, CA
    2010 Gray Tacoma TRD
    none yet ...
    uh, yeah
    don't put anything in your oil
  8. May 27, 2011 at 9:14 AM
    TacoOwner?
    Joshua
    Camas/Spokane, WA
    And why is that? What if I just add some water to thin it out? Jk bummer, time for another change. So why does everyone not like it? Not just, it doesn't work. Anyone personally have a problem with the oil stabilizer? Lots of people seem to use it in new and old vehicle. Some using whole bottle others only half. So why do taco owners not like it? I'm just curious, because I don't know. Not trying to start a war :)
    Josh
  9. May 27, 2011 at 12:22 PM
    sickboy
    sickboy Active Member
    Houston, TX
    '13 TRD LB 4X4 SUPER WHITE
    Use a good oil and you will not need additives like Lucas.
    I run Pennzoil Ultra personally but any oil that meets the required specs should be fine without adding crap. (unless its in a purple bottle.. avoid that crap too)
