lug centric pro comps just wont balance
Discussion in 'Wheels & Tires' started by marintacoma, Nov 15, 2012.
  1. Nov 15, 2012 at 7:55 PM
    marintacoma
    marintacoma [OP] Well-Known Member
    Marin
    2004 white toyota tacoma 4x4 trd
    tried having the shop who installed them balance them, ive been back 4 times and everytime i leave with my steering wheel shaking worse.. the shop has been very cooperative but it is just not helping. they keep saying the machines been zero'd and theyve tried dynamic and conical balancing! the guy said its hard because they cant put the weights on the outside or it will look ugly on my pro comp 7031s. what is going on? do i just have to sacrafice my ride because i got lug centric rims? [​IMG]
  2. Nov 15, 2012 at 7:58 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    See if you can find someone to lugcentruc balance the wheels..
    Supposably there is a difference when you balance between hub and lug centric.
  3. Nov 15, 2012 at 8:06 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    This may or may not help, but do you have the right lug nuts?
  4. Nov 15, 2012 at 8:14 PM
    marintacoma
    Marin
    i asked and they said they know that my rims are lug centric, they are using a roadforce balancer. i already have aftermarket lugs
  5. Nov 15, 2012 at 8:14 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i believe they make adapters to make them hubcetric. what my shop did was put the stick on weights as close to the front as possible. maybe that will help
  6. Nov 15, 2012 at 8:19 PM
    marintacoma
    Marin
    i am going to try costco, suprisingly i never had issues with them before, plus i bought my tires there, if that doesnt work i will probably bring it to the shop that actually sells pro comps...
  7. Nov 15, 2012 at 10:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If all else fails....You may want to consider EQUAL tire balancing compound.
    You have an 04, so you don't have to worry about the TPMS. You should be good..... just make sure the shop is experienced with installing it and knows the proper amount to use.
  8. Nov 16, 2012 at 5:26 PM
    marintacoma
    Marin
    costco actually did a decent job, its 95% perfect except for a tiny bit of shake around 62 but it goes away once i get a little higher
  9. Nov 19, 2012 at 7:50 PM
    toytaco11
    toytaco11 Well-Known Member
    Albuquerque
    11 TRD 4x4 lwb doublecab
    coming soon!
    Mines balanced perfectly!
