lug nut bolts keep breaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Aug 1, 2011.
  1. Aug 1, 2011 at 2:09 PM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I keep having the problem of the lug nut bolts breaking when Im taking off my wheels. Anyone else have this problem or know a fix.
  2. Aug 1, 2011 at 2:11 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    breaking off??
    like breaking the stud, or the lug nut? pics?
  3. Aug 1, 2011 at 2:33 PM
    07TaCo07
    oregon
    Breaking the stud with lug nut still on stud. Got no pic yet. Ill see about one once the truck is done at les schwabs
  4. Aug 1, 2011 at 3:24 PM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    This is the purpose of anti-seize. It allows the bolt/nut to accurately tighten down to the required specifications. It also keeps the 2 parts from fusing together with road salt, rust, dirt, and grime. I've NEVER broke a stud on any vehicle since I started using anti-seize and a torque wrench. Do not allow your mechanic or tire shop to use an impact wrench but hand torque down all lug nuts to no more than 95 lbs. You will also notice that your properly balanced tires will not shake if each nut is evenly torqued.
  5. Aug 1, 2011 at 3:26 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use a 4-way wrench or impact wrench. Ratchets, breaker bars, and the factory tool put an angled torque on the stud which will allow for easier breakage.
    The proper rated torque stick will properly install lugs with an impact.
  6. Aug 1, 2011 at 3:59 PM
    07TaCo07
    oregon
    Is anti seize the same as loc tight or what brand anti seize should I get?
  7. Aug 1, 2011 at 5:11 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Loctite is the opposite of anti-seize. 3m makes a good caliper grease/antiseize.
  8. Aug 1, 2011 at 5:17 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    I have same problem..took truck to get tire rotated/ balanced. following week worked on brakes, broke two bolts trying to get em off. they used impact wrench and over torqued the F out of em. wish i had known about this prior. got me new ones now to replace em, maybe this weekend.
  9. Aug 1, 2011 at 5:25 PM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    Lugnuts on our trucks the torque is only 83 ft lbs. You really should never use any lubricants like anti seize on them cause it makes it more prone to loosen up .
  10. Aug 1, 2011 at 6:12 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Now I'm confused...
    - Do use Anti-seize. Don't use an impact gun. Do use a torque bar. 95 ft/lbs
    - Do use an impact gun. Don't use a bar.
    - Don't use anti-seize. 83 ft/lbs
    What's the proper answer? Where's Chris when you need him
  11. Aug 1, 2011 at 6:25 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Yeah, I would never use an anti seize on a lug nut stud.( More risk of your wheel falling off) You should be fine Getting your wheels off if your torqued down to the proper specifications.
  12. Aug 1, 2011 at 6:27 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Anti Seize is just what it says. It stops two pieces from seizing together. It is not grease that BTW you should never use because of loosening. I have been using anti seize for years and never had any problem with pieces seizing together or with anything loosening.
  13. Aug 1, 2011 at 6:50 PM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    maalox is poor man's anti seize
  14. Aug 1, 2011 at 6:53 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    X2
  15. Aug 1, 2011 at 6:56 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    PreRunner SR5 TRD Sport
    Bull bar, wet suit seat covers, Accessory meter repair, Fog Lights with stick on, console lock.
  16. Aug 1, 2011 at 7:01 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    DO NOT, Do not, put anything on lug studs. PB blaster, anti-seize, it's all friction modifiers. Not a good idea on the things that hold your wheels on.
    Scrub dirty, rusty studs with a wire brush.
    If you keep breaking the studs off in the lug nuts while trying to remove them, I'd have to say that the lugs are cross-threaded onto the studs. Do they get really hard to turn, then break?
    Correct Torque is 83 Ft Lbs. (or an orange torque stick used with an air gun) Torque wrench, impact gun, don't matter. 80-83 Ft Lbs.
  17. Aug 1, 2011 at 7:04 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    If you live anywhere that uses salt on the roads you have 3 options:
    Either you have stainless studs, anti-sieze gooped all over the studs, or you snap every stud off when you try to break lug nuts loose. Anti-seize will in no way loosen a properly torqued lug nut. And you shouldn't impact a lug nut on because it tends to cock the wheel sideways and the torques on each lug will be significantly different.
  18. Aug 1, 2011 at 7:06 PM
    07TaCo07
    oregon
    Les schwabs said 83lbs
  19. Aug 1, 2011 at 7:07 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I drove in Massachusetts for 6 years and never had a problem. My family has lived there for 35 years and no problems with lug nuts.
    As stated multiple times above, do not use anti seize. It will not "loosen" the lugs, but it will modify the amount of friction needed to tighten them, causing them to be overtorqued, stressing the threads on both the stud and the lug nut.
  20. Aug 1, 2011 at 7:09 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I've never used anti-seize and never broken a stud, but then I rotate my own tires and have never found the need to have them balanced, no need to let someone else screw shit up like it seems has happened here.
    Never bother with a torque wrench for lug nuts either, can't overtorque with the oem tire iron. ;)
