Lug Nut question: 2005 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gpfwvu, Oct 24, 2020.
  1. Oct 24, 2020 at 10:44 AM
    gpfwvu
    gpfwvu [OP] Active Member
    2011 Toyota Tacoma Long Bed 2WD
    Stock
    My 05 long bed 4x4 Tacoma has the steel wheels and I’m putting on a set of Tacoma alloy wheels. Both are stock 16x7.
    Can I use the lugs from my steel wheels with the alloy wheels? Are they the same?
    Thanks!!!
  2. Oct 24, 2020 at 10:51 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Steelies are conical seat, alloys are shanked. No dice...
    TnShooter and ovrlndkull like this.
  3. Oct 24, 2020 at 11:01 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Simple answer. No.
    TnShooter likes this.
  4. Oct 24, 2020 at 11:59 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    And you can't use universal mag lug nuts; they have shank diameters of .685 and .740. Need to get Toyota spec lugs - they have .725 diameter shanks and a depth of .550 (.875 dia shank for larger Toyota/Lexus trucks and SUVs). Plus, the trucks use longer lug nuts - 1.8" vs 1.5" for the cars. See Gorilla part# 73138XL for reference.
  5. Oct 24, 2020 at 6:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I have a full set of OEM lugs from a 2015 Off Road you can have for free plus shipping. They only saw about a year of use before going to a TRD wheel that required special lugs. Shipping probably won't be cheap, but likely cheaper than new OEM lugs.
    wmb67 likes this.
  6. Oct 24, 2020 at 6:59 PM
    Fishing Grizzly
    Fishing Grizzly Well-Known Member
    Joe
    Southern Idaho
    2011 DCSB TRD OR 6 speed
    ARB Bumper URD Short Shifter Leer 100r Caliraised bed stiffeners Meso dome light Ironman stage 2 w/ constant load leafs
    I’d recommend going with new one piece lug nuts while you’re switching. Gorilla makes a good set that are all locks. My OE lug nuts swelled and couldn’t fit in the lug wrench, switched them out today.
  7. Oct 24, 2020 at 7:56 PM
    gpfwvu
    Stock
    I really appreciate the offer! Thank you! I was able to find a set locally and the price was right.
    Thanks again!
    crashnburn80[QUOTED] likes this.
  8. Oct 25, 2020 at 1:21 PM
    gpfwvu
    Stock
    Chuy,
    Thanks for the info. I noticed the stock lugs that came on my 2011 Tacoma with alloy wheels has the 1.5" full length (including the shank) versus the 1.8" you describe above. I went to Gorilla's website and see the 1.8" you mentioned. Is the length a necessity or a preference?
    Thanks again for your help!
