Lug nut question on old trd wheels
Discussion in '4th Gen. Tacomas (2024+)' started by Kai94, Jun 29, 2024.
  1. Jun 29, 2024 at 8:28 PM
    Kai94
    Kai94 [OP] New Member
    Kai
    2024 Tacoma
    Hello friends,
    I recently bought used trd 17” wheels, not sure what year they are but was told they are somewhere between 2003-2009. I tried putting them on my 2024 Tacoma sr but the lug nuts are too small to thread onto the prongs and my stock lug nuts from my old wheel don’t go in flush into the bolts for the lug nuts so they aren’t able to thread in all the way.
    I was wondering if anyone knows what kind of lug nuts will fit on my 2024 prongs with these older model trd rims. Any advice would be much appreciated, thank you!
  2. Jun 29, 2024 at 8:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Pretty sure the 2024 Tacoma went to an M14x1.5 lug nut size.
    All the previous gens were M12
  3. Jun 29, 2024 at 8:38 PM
    Texas
    Texas Well-Known Member
    I think the center bore also changed as well. Like 106mm to 96mm on the 4th gens. Correct me if I am wrong.
    Jeff Lange likes this.
  4. Jun 29, 2024 at 8:44 PM
    TnShooter
    Deogee
    STOCK
    I believe you are correct.
    I think @Discount Tire posted the specs at one time.
  5. Jul 5, 2024 at 1:08 AM
    Kai94
    Kai
    2024 Tacoma
    Still doesn’t quite answer my question
  6. Jul 5, 2024 at 4:29 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    @Kai94 the wheels you have were designed for m12 "prongs" ...studs and lug nuts. The truck you have has "prongs"...studs that are m14. The stock lug nuts will not fit the older wheels because...
    1. The design of the nut is not made to fit the wheel.
    2. They are not the correct bolt thread size.
    If the wheels are going to fit this truck. You may need different m14 lug nuts. You might not find any... That fit this wheel.
    You may need a center hug ring spacer from 106mm to 96mm. Which you will find Amazon for cheap.
    Texas and Jeffvt0508 like this.
  7. Jul 7, 2024 at 8:01 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The wheels won’t work.
  8. Jul 8, 2024 at 4:58 PM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    There are some other threads about this, here or on tacoma4g.com. What I recall is that someone found some 3rd party lug nuts that would fit. Other option was to drill out the holes for the larger lug nuts. A center hole space was also required.
  9. Jul 9, 2024 at 3:21 PM
    Kai94
    Kai
    2024 Tacoma
  10. Jul 9, 2024 at 4:10 PM
    Sharpish
    Brian
    You’re still up against the smaller Center bore and drastically different offset of the wheels
