Lug Nut Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VolNut, Aug 31, 2010.
  1. Aug 31, 2010 at 8:01 AM
    VolNut
    VolNut [OP] Well-Known Member
    Rick
    TN
    I picked up a set of FJ wheels and just wanted to make sure I can use the lugs that are on my truck now. I have the aluminum wheels, not the steel ones. Thanks
  2. Aug 31, 2010 at 1:57 PM
    VolNut
    Rick
    TN
    Afternoon bump.
  3. Aug 31, 2010 at 1:58 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Are the FJ steel or aluminum?
  4. Aug 31, 2010 at 2:05 PM
    VolNut
    Rick
    TN
    Aluminum I think, they look like this (not my pic)
  5. Aug 31, 2010 at 2:08 PM
    S.B.
    Sean
    If both sets are aluminum then you should be good to use your current lug nuts.
  6. Aug 31, 2010 at 3:20 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The FJ rims take conical seat lugs as far as I know.
    I believe the TRD OR rims take shank and washer lugs. So if you have the TRD OR rims you would need different lugs. Someone correct me if I'm wrong.
  7. Aug 31, 2010 at 4:50 PM
    m3zy6
    m3zy6 Well-Known Member
    Roanoke, VA
    07 AC TRDOR 4x4 6spd
    I dont know about the normal alloys, but the gunmetal TRDs that I put on today have the washer lugs. The stock FJ nuts are twice as long as my TRD OR ones, but they both work in the wheels.
    OP, just look at the nut perch. If it is angled then you need cone style nuts, if it is flat then you can use your stockers.
  8. Aug 31, 2010 at 7:08 PM
    KPT
    09 Prerunner
    Really depends which stock alloy wheels he has. My taco came with the gulf states toyota alloy wheels, with conical seat lugs.
  9. Aug 31, 2010 at 7:11 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I'm using the ones that came with the truck. Trd or lug nuts no problems what so ever.
  10. Aug 31, 2010 at 7:22 PM
    VolNut
    Rick
    TN
    These are my stocks. Thanks so far fellas. The FJ nut perch is flat. So I'm thinking the stock ones will work.
  11. Aug 31, 2010 at 7:24 PM
    senor taco
    Monterey Bay, Ca
    Those are the same stock wheels I had^^
  12. Aug 31, 2010 at 7:25 PM
    KPT
    09 Prerunner
    Those are the stock TRD Or wheels, so according to senor taco's and m3zy6's posts above, you are good to go.
  13. Aug 31, 2010 at 7:35 PM
    VolNut
    Rick
    TN
    Mines not an OR though, its an SR5. Still good to go?
  14. Aug 31, 2010 at 9:44 PM
    senor taco
    Monterey Bay, Ca
    Yeah, the wheels are the same just different tires.
  15. Aug 31, 2010 at 11:08 PM
    pinktaco808
    pinktaco808 Hot Steppa
    post lug nut people duhh it faster
  16. Sep 1, 2010 at 7:38 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    I like the look of the alloy Tacoma wheels much better than the alloys that came on my FJ!
  17. Sep 1, 2010 at 7:52 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Negative. The Alloy rims on both the Tacoma and FJ take the "Mag" or "shank" style lug nuts. Steel rims will take the conical lug nuts.
    If you have lug nuts that look like this then they will not work on the rims and I would not recommend attempting to use them.
    If they look like the lower lug nut with a flat surface and washer then yes those are the correct lug nuts. The other lug nut is there to only show the difference between the surface's.
  18. Sep 1, 2010 at 8:51 AM
    KPT
    09 Prerunner
    Yeah m3zy6 already corrected me above about the FJ rims.
    But, as I noted, I had the "Gulf States" alloy wheels that come stock on most tacomas down here, and they were conical seat...so not all of the Tacoma alloys are shank, just so we are clear for anyone who digs this thread up later.
  19. Sep 1, 2010 at 12:35 PM
    VolNut
    Rick
    TN
    The grass is always greener they say.
    Thanks to everyone for the help. As usual you guys rock!
