Lug nut ?s
Discussion in 'Wheels & Tires' started by DoubleTake, May 9, 2012.
  1. May 9, 2012 at 2:33 PM
    DoubleTake
    DoubleTake [OP] Well-Known Member
    My 98 Tacoma came with 05-current TRD sport alloys on it. I am taking them off and going to run either the 16" split spoke wheels off an 01-02, or the 5 spoke 16" aluminums off an 01-04. Am I going to need different lug nuts for the different wheels? If so, what size lug nuts? I found the mag type lug nuts, 12x1.5 size I believe for around $26 for 24. Not sure if I need acorn or mag type and if that is the right size. Thanks
  2. May 9, 2012 at 10:26 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    if i recall correctly, they all use the shank style lug nuts so you should be fine with what you have.
  3. May 9, 2012 at 10:29 PM
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    he is right, it should be shank style. But I would recommend getting the rims first before you purchase the lug nuts.
  4. May 30, 2012 at 7:04 AM
    DoubleTake
    Ok, so evidentally there was two different style of the 16" alum split spoke wheels that came on the 01-04. If the center cap said Toyota it was port installed and if it had the Toyota emblem it had different lug nuts. Anybody know which lug nuts and part numbers I would need? I'm not even sure which lug nuts I would need. My center caps have Toyota written on them.
  5. May 30, 2012 at 5:54 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    care to post a picture of the wheels you're referring too. i'm drawing a blank. i know of only one style 16" alloy offered on the '01-04 tacomas.
