Lug nut torque, does it matter?
Discussion in 'Wheels & Tires' started by OkTacoTRD, Oct 14, 2016.
  1. Oct 14, 2016 at 9:17 AM
    OkTacoTRD
    OkTacoTRD [OP] Well-Known Member
    Jerry
    2016 Black Tacoma TRD Off Road
    I just had all four times replaced and of course, like all tire shops, they use an air impact wrench to install the lug nuts. My guess is they use the same force for my aluminum Tacoma wheels that they use on the giant steel wheels they install on heavy equipment.
    So, my question is do you think it really matters, and if not, is the only downside likely to be snapping of a lug bolt? I guess it could damage the wheel as well, but I'm guessing no tire shop around actually torques them to the correct range.
  2. Oct 14, 2016 at 9:22 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Yes, it matters. I always check the torque after tire work because very few shops get it right.
    NAAC3TACO and rmepilot like this.
  3. Oct 14, 2016 at 9:25 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    They may have used a torque stick on the impact. It's a color coded extension that twists when the allowed torque is reached. Helps with preventing over-tightening the lug nuts.
    Edit: Did you see them use something like this?
  4. Oct 14, 2016 at 9:25 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Damage wheel, warp rotors, uneven torque can create vibration and warpage, if ever on the side of the road with a flat you need the strength of Hercules to turn the lug nuts, potential to strip the threads, and I could go on but you get the point.
    OG_Tacoma and Shelf Life like this.
  5. Oct 14, 2016 at 9:33 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I have never seen any shop hand-torque lugnuts. I've only seen torque sticks. The respectable car repair Youtube channels like South Main Auto and EricTheCarGuy both use torque sticks.
  6. Oct 14, 2016 at 9:34 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    I have worked for two companies that require techs to properly torque wheels. Americas Tire (same as Discount Tire), and Firestone Complete Auto Care. Might wanna hit them up for your regular rotations/ balances, etc. As stated above, over torqued wheels can cause plenty of problems. And obviously under torqued wheels could potentially fall off.
  7. Oct 14, 2016 at 9:34 AM
    Shelf Life
    Rob
    Central Oregon
    True. I had to kick the lug nut wrench about 3 times to loosen a few lug nuts after one shops fine work. Some of them just put max force on every vehicle they work on.
    OkTacoTRD[OP] likes this.
  8. Oct 14, 2016 at 9:34 AM
    OkTacoTRD
    Jerry
    No I didn't. I may need to buy a torque wrench....
  9. Oct 14, 2016 at 9:36 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    And a breaker bar...
    OkTacoTRD[QUOTED][OP] likes this.
  10. Oct 14, 2016 at 9:37 AM
    OkTacoTRD
    Jerry
    After the local independent tire shop installed them (they were $50.00 per tire cheaper than anywhere else I could find them) I still had trouble with the balance. Went back several times and finally just took them to the dealership and had them road force balance them. Surely they torqued them correctly........
  11. Oct 14, 2016 at 9:38 AM
    OkTacoTRD
    Jerry
    Is a 3/8 inch torque wrench adequate or will I need a 1/2 inch?
  12. Oct 14, 2016 at 9:39 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    1/2" - Harbor Freight is good enough. It won't be Snap-On Tool accurate but it won't be 30ft-lb's off either.
  13. Oct 14, 2016 at 9:39 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Costco tightens the lugs with a torque wrench. I thanked the tech for doing that, and he said it is Costco policy to do this. If I ever need tire service, I always ask to have shops torque with a torque wrench. I don't need any of my lugs snapped off.
  14. Oct 14, 2016 at 9:40 AM
    OkTacoTRD
    Jerry
    I have a friend who recommended I get an 18 volt portable impact wrench to make it easier. But, I checked out their specs and they are around 200 lbs of torque!
  15. Oct 14, 2016 at 9:41 AM
    KenLyns
    Belly of the Beast
    Dealer techs are probably under the most time pressure to do jobs quicker. Some of them even use cordless impacts (set to a low clutch setting) to run down spark plugs :eek:.
  16. Oct 14, 2016 at 9:41 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Impact wrench does the job perfectly fine. No need for torque
    Storman likes this.
  17. Oct 14, 2016 at 9:42 AM
    Shelf Life
    Rob
    Central Oregon
    This^^
  18. Oct 14, 2016 at 9:42 AM
    OkTacoTRD
    Jerry
    The portable impact wrench I mentioned or the one they use in the shop?
  19. Oct 14, 2016 at 9:42 AM
    Clearwater Bill
    Billy
    Largo Florida
    Max. They adjust.
  20. Oct 14, 2016 at 9:43 AM
    OkTacoTRD
    Jerry
    The one I looked out didn't seem to have one (dewalt). Maybe I overlooked it.
