Lug nut variation between years???
Discussion in 'Wheels & Tires' started by TxStVanWilder, Jan 19, 2022.
  1. Jan 19, 2022 at 11:13 AM
    TxStVanWilder
    TxStVanWilder [OP] The Pale Horse
    Tx
    2013 TRD Sport
    Went to discount tire *enter large sigh here* and had a set of 2019 take off's to swap on to my 2013. The owner of the 2019 wheels gave me the lug nuts as well when i purchased the wheels. They're still in a box on my shelf at home. When i went to discount the person at the counter mentioned there were a difference in lug nuts between my 2013 and the 2019 wheels that i was going to have them install and i would need to purchase new lug nuts from them. Something along the lines of the 2019 will use a more conical type lug nut to fit the wheel vs a 2013 lug nut that has a flat face.
    I chose not to have them balance and swap the wheels due to it being a $125 charge to swap wheels and balance them. So before i swap the wheels over myself using the lugs from the 2013 wheels, i was wondering if anyone was more well versed than i am in this situation to tell me if the lugs are a different style and will/wont work with the wheels
  2. Jan 19, 2022 at 4:25 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Post a pic of the two wheels.
  3. Jan 19, 2022 at 4:28 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Steel or aluminum take offs?
    3rd gen OEM aluminum wheels use flat faced nuts. TRD aftermarket, beadlock, use cone seat.
    The nuts match the wheels. So use the '19 nuts with the '19 wheels and good to go.
  4. Jan 19, 2022 at 4:28 PM
    Bishop84
    Bishop84 Well-Known Member
    Nope, 1996 lugs fit 2022 lugs.
    That said some wheels suit the longer lugs than the shorter ones.
    As long as they are the alloy lugs with washers and they are 21mm you are good.
    TxStVanWilder[OP] likes this.
  5. Jan 19, 2022 at 4:32 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Wheel studs are the same thread diameter and thread pitch as the same as the nuts.
