Lug Nuts for 2005 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B747SP, Mar 16, 2025.
  1. Mar 16, 2025 at 5:53 PM
    B747SP
    B747SP [OP] Member
    JT
    2005 Tacoma TRD Access Cab 4WD 4.0L V6
    Hello All:
    I'm due to replace my tires and the last time I had the tires rotated, I was told by the gentleman at Costco that my lug nuts were stripped and needed to be replaced. I've looked at several places on line and over the phone for new lug nuts, i.e. Amazon, Auto Zone, along with a slew of others, as well as a Toyota parts department. The Toyota parts guy said they didn't have any in stock and didn't know when they'd be back in stock, and most other online sites are either listing them at a ridiculously low price (making me think they're not OEM, or some cheap knock off), or they're priced so crazy high that I think I'm getting ripped off. Can anybody shed some light on what size I need, where I should get them, and approximately what I should be paying for these? I think I'm wanting the 12X1.5 but I've seen a couple of different hex sizes associated with the 12X1.5, which I have no idea means. Any assistance would be greatly appreciated. Thank you.
  2. Mar 16, 2025 at 6:10 PM
    Bishop84
    Bishop84 Well-Known Member
    You need lugs with washers for your alloys.
    USD would probably be 1.50 each.
    B747SP[OP] likes this.
  3. Mar 16, 2025 at 6:15 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    your lug nuts are probably swollen. Toyota went with a pressed in cap instead of solid steel nuts. Over time the cap swells from being abused by impact guns.
  4. Mar 16, 2025 at 6:39 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Try napa, thats where I get mine.
  5. Mar 16, 2025 at 11:36 PM
    B747SP
    B747SP [OP] Member
    JT
    Thank you. I will check these out and will definitely get lugs with washers.
  6. Mar 16, 2025 at 11:38 PM
    B747SP
    B747SP [OP] Member
    JT
    Dang, I didn't even think to call NAPA. I'll check them too. Thank you.
  7. Mar 16, 2025 at 11:40 PM
    B747SP
    B747SP [OP] Member
    JT
    Hmmm, never knew lug nuts could get swollen. Then again, I'm not mechanically inclined so I'm glad I happened across this forum and found that out. Thanks for the info.
  8. Mar 17, 2025 at 7:55 AM
    winkeldc
    winkeldc Well-Known Member
    2014 Reg Cab 4x4
    If you have the stock lug wrench only, make sure it fits the hex head on the new ones you buy. Don't want to be on the side of the road only to find out the wrench is too big or small for the replacements. I believe the stock hex head size is 21mm, but I could be misremembering it that. The 12x1.5 bolt/thread can have a different head, so some replacements might need a 19mm (3/4) socket vs the stock 21mm socket; that's what the different hex size means.
  9. Mar 17, 2025 at 9:06 AM
    B747SP
    B747SP [OP] Member
    JT
    Thank you. As crazy as this sounds I'll probably bring in my lug wrench to whenever I get these lug nuts. Then I'll tell the Costco guys what size hex they are so don't strip these new ones.
  10. Mar 17, 2025 at 9:20 AM
    winkeldc
    2014 Reg Cab 4x4
    It's most like what others have said, your lug nuts swelled a bit and they had to go next size up socket because the right sized socket no longer fit. They do make a half-size step up lug nut socket for this problem, but the shop might not have had, the tech wasn't aware of the swelling issue and assumed the 21mm was too small, or yours were really bad.
  11. Mar 18, 2025 at 11:41 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    My nuts were swollen. Rough finding out about something like that at Discount Tire.
  12. Mar 18, 2025 at 1:09 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    They don't actually swell but it has that appearance. OEM shank style wheel nuts have a chrome shell that deforms when hit by air guns and battery impact wrenches. The lug nut itself is likely fine but a socket will not easily slide over a deformed shell. Any current Toyota 12mm shank lug nut will fit. I currently have the lug nuts from my daughter’s 2024 Corolla on my 07. They are chrome and don't have the shell.
  13. Mar 20, 2025 at 10:05 PM
    WestSeattle
    WestSeattle Active Member
    2011 Toyota tacoma 4x4 dbl
    I hate swollen nuts. Discount guys told me about my swollen nuts. Glad they did. Traded out my chromes for some black nuts and never looked back. Bezos store had them. Not expensive.
