Lug Nuts for Moto Metal 951b
Discussion in 'Wheels & Tires' started by wrmathis, Aug 18, 2010.
  1. Aug 18, 2010 at 4:32 AM
    wrmathis
    wrmathis [OP] Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I am looking at getting the Moto Metal 951b and was wondering if i needed new lug nuts or can i use the ones that i have on my truck currently. I have a 2006 TRD OR 4x4 with stock rims and lug nuts. if i do need new ones, what kinda do i need to get and where online can i get them?
  2. Aug 18, 2010 at 5:00 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I was told that you need new ones when I got the same wheels. I ended up with a Gorilla Spline drive kit, similar to these:
    http://www.gorilla-auto.com/gorilla.locks.page_25
    It's been a while since I've rotated them, so I can't remember 100% for sure, but I believe its the "Short Mag" found on that link. I was told the Acorn type isn't the proper type for the moto metals, and that the ones I have now center the wheel on the hub properly.
    Having said that, I did use the factory ones for a very short time until someone told me that was incorrect. They worked, but these are also working, plus you need a key to get them off which is a plus.
    Edit: now that I look again, it could be the standard mag. Sorry I'm not sure which I'm using, hope this helps a little though.
  3. Aug 18, 2010 at 5:06 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    thanks i appreciate what u gave me. do u know what size they are? 12mm x 1.25 or 12 mm x 1.50?
  4. Aug 18, 2010 at 5:25 AM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    It's 12x1.5 and you're looking for an ET-style set of lugs. They have a small shank that helps center the wheels on the hub. Hope this helps
  5. Aug 18, 2010 at 7:13 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    does the length matter? 1.4in compared to 1.8in lug nuts?
    and sorry for all the questions. just lookin for the right ones
  6. Aug 18, 2010 at 11:23 AM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    length shouldn't be a problem, considering that the hub application is gonna take care of that for you
