Lug nuts - "swollen" or is Costco crazy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by COoffRD, Jul 6, 2014.
  1. Jul 7, 2014 at 4:49 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    These both are correct. I used to see both of these a lot at the shops I worked at. We always used to recommend switching to the cast units like Gorilla rather than getting another set of the two-piece nuts, because they don't hold up long-term. The one-piece cast nuts might eventually get rusty, but you don't have to worry about them losing their casing and your lug wrench suddenly not fitting.
  2. Jul 7, 2014 at 5:20 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    If your 21 mm fits good, I would ask them to show you what they are using.
    Lester Lugnut likes this.
  3. Jul 7, 2014 at 5:44 AM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    OP....even though a life time tire rotation may sound enticing....I would be very hesitant on letting a place like Costco...walmart...even discount tire rotate my tires on a regular basis....at the very least make sure you double check your lugs and torque when you get home
  4. Jul 7, 2014 at 7:28 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    :thumbsup:
  5. Jul 7, 2014 at 9:39 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I think most people don't realize some lug nuts are 2 pieces.
    I've had some where the outer casing got deformed after repeated used and the socket no longer fit. I've even had some where the outer casing fell apart.
  6. Jul 7, 2014 at 2:39 PM
    COoffRD
    COoffRD [OP] ShouldaKeptTheOldOne
    Val
    Vermont
    '05 Taco, 6sp
    I'm confused because I inspected several of them up close and they look fine.
    Yes, I rolled them around in my hands. And no, I did not put them in my mouth.
  7. Jul 7, 2014 at 2:49 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    10/10 for thread title alone. Would read again
  8. Jul 7, 2014 at 7:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Damn you! I spit coffee all over my keyboard! [​IMG]
    Did you lick them?
  9. Jul 7, 2014 at 7:42 PM
    DeltaSteve
    DeltaSteve Social Critic
    FW,TX near TCU
    '09 White TRD access
    KING 2.0" PERFORMANCE SERIES REMOTE RESERVOIR COILOVER SHOCK W COILOVERS, TC UCA, OME DAKAR SPRINGS, RELENTLESS PLATE R BUMPER and MORE :)
    Go down to the county health department, they track statistics on stuff like that.
  10. Jul 7, 2014 at 7:52 PM
    kodiak141
    kodiak141 Active Member
    lol you guys are terrible :)
  11. Jul 7, 2014 at 8:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    This. The Costco mechanics were likely using a 13/16" socket (or possibly torque-stick, since they come in fewer sizes). 13/16" is 20.6 mm, so it will be a tight fit in some cases and interference in others.
    It doesn't help that some popular aftermarket lugnuts for 12x1.5mm thread (like McGard) actually are designed for 13/16" nominal socket size.
    Go somewhere else more import-friendly.
  12. Jul 7, 2014 at 8:12 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  13. Jul 7, 2014 at 8:14 PM
    metal4130
    metal4130 Well-Known Member
    Eric
    Central IL
    13 DCSB PreRunner
    Good call about the socket size. A 13/16" is 0.8125 and a 21mm is 0.8267
    If they use the 13/16" it will be tight but it does still fit. I have rotated my tires using a 13/16" socket but I don't use impact tools.
  14. Jul 7, 2014 at 8:20 PM
    OffroadToy
    redcon likes this.
  15. Jul 7, 2014 at 8:24 PM
    #35
    KenLyns
    Belly of the Beast
  16. Jul 7, 2014 at 8:25 PM
    #36
    InSight Retrofits
    InSight Retrofits Closed
    Alright time for a real response.
    As lug nuts are taken off and put on they do "swell" but it's actually the cheap ass nuts being twisted both ways and eventually the sockets don't fit them anymore because the walls aren't straight.
    The cap separates from the lug nut and it's harder to get the socket on.
    So yes, it does happen. Doesn't necessarily mean you need new ones, but it takes them twice as long to get their socket on them. Poor guys :p
  17. Jul 7, 2014 at 9:24 PM
    #37
    COoffRD
    Val
    Vermont
    '05 Taco, 6sp
    Thanks all for the entertainment...but especially for the info. Still undecided whether to buy new nuts - it's not a big investment, but I hate wasting money on someone else's idiocy!
    You guys are weird and awesome.
  18. Jul 7, 2014 at 9:38 PM
    #38
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    ^This. I work at Americas Tire and I see this a lot with older Toyotas and damn near every Dodge truck that comes into the shop. We DO use 21mm sockets and they just don't fit when the lugs are really hot after driving in the summer heat. We use 7/8" sockets on the Dodge trucks and they don't fit either most of the time. So OP, buy the lug nuts because the day u get a flat and have to change a tire on the side of the road you'll regret keeping those crappy 2 piece lug nuts. All joking aside.
  19. Jul 8, 2014 at 7:29 AM
    #39
    oldstick
    oldstick Medicare Member
    GA
    Interesting, I learned something new today.
  20. Sep 18, 2018 at 1:02 AM
    #40
    Roadie303
    Roadie303 New Member
    This topic has got to be the most absurd and hilarious illustration of peoples understanding of their vehicles. But, this problem of car manufacturers using a sub-standard part for lug nuts is very wide spread, check the class action against Ford. And Dodge, Toyota and other carmakers use them on various models.
    I do roadside assitance and have seen these bad lugs many times. One thing I haven't seen mentioned is how sometimes the cap breaks loose from the base nut and it just spins around when you attempt to take them off. When that happens, I have to tell them they better get a tow because they only way to get them off is cutting or special tools; sorry I dont get paid for that kind of job.
    So my advice to anyone with these kind of nuts, and you know who you are..or at least you should. If the mechs tell you to change them, I would do it. And if they are bad on one wheel I'd check them all.
    Hope I dont sound preachy because it is the silliest thing you ever heard until it happens to you.
