Lug nuts
Discussion in 'Florida' started by 2013TacoDCLB, Mar 6, 2023.
  1. Mar 6, 2023 at 8:11 PM
    2013TacoDCLB
    2013TacoDCLB [OP] Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    Hi,
    What lug nuts should I have in my truck?
    Mark
  2. Mar 6, 2023 at 8:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are your wheels OEM?
    Are they Steel or Aluminum?
    The lug nuts are different for both.
    Dave315 likes this.
  3. Apr 15, 2023 at 11:14 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Alum/mags here are some:
    Amazon.com: SCITOO M12x1.5 Lug Nuts Black, 24PCS 1.45" Tall 12x1.5 Lug Nuts Thread Close End, 13/16" 21mm Hex Fits for Toyota 4Runner/ Avalon/Avanza/Camry/Celica/Corolla 1997-2016 : Automotive
    Whatever you buy if painted you must repaint a few coats of Rustoleum before using so they do not rust - will if not painted a few coats. Simply flip them over in the box and paint and allow to dry overnight or you will mess them up till paint dries well. If chrome ones they do rust on all Amazon ones so....
    These also have a slight taper on seat so handle your steel spare temporarily (only).
