Lug nuts
Discussion in 'Wheels & Tires' started by CometKat, May 2, 2008.
  1. May 2, 2008 at 8:28 AM
    CometKat
    CometKat [OP] Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    I hope this is not too dumb a question. But is there any difference in the lug nuts for a 05-08 steel wheel vs. an alloy (quality or otherwise)? I see lots of OEM alloy wheels for sale without the nuts.
  2. May 2, 2008 at 8:44 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Seems like a good question to me. I probably wouldn't have asked, but I could see there might be a difference.
  3. May 3, 2008 at 8:39 AM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    There is a difference between stock steel wheels and alloy wheels.
    Steelies are acorn shaped:
    Alloys are short shank design:
  4. May 3, 2008 at 8:45 AM
    CometKat
    Carson City NV
    Does that mean they are not interchangeable?
  5. May 3, 2008 at 2:57 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    That is correct, not interchangeable.
  6. May 3, 2008 at 3:08 PM
    ChibbMD
    ChibbMD Well-Known Member
    Dallas, TX
    08 PreRunner Double Cab
    Yep, this is correct. They are not interchangeable. I found this out first-hand when I upgraded my stock steel wheels for alloys. I was able to find a dealership that had some used take-offs but they still cost me $5 or $6 a piece. Ouch!
  7. May 9, 2008 at 5:37 PM
    yak
    yak member
    so cal
    08 indigo dc prerunner sr5
    roll n lock bed cover - tinted window - debadge - blue interior light
    I just changed my 08 stock steel wheel with 07 TRD sport wheel, and it seems OK. Did i do something wrong?
    madwheeling likes this.
  8. May 10, 2008 at 2:08 PM
    mikedaz
    mikedaz Active Member
    NH.
    07 SR5 I4 4x4, access cab, 5 speed,
    bug deflector, vent guards, running boards ,stainless tip,summer + winter tires + wheels,secondary filter removed,60 series delta flowmaster,tow hitch,pop+lock
    I found this out too when I up graded to alloys. You need to get the shank style lug nuts. I bought them at the dealer for $2.50 each. $60. total for 24 lug nuts.
  9. May 11, 2008 at 10:39 AM
    yak
    yak member
    so cal
    mikedaz ans chibb, How are they not work? Do they not fit? Again, cause I did mine, and seeems to work. Make me worry now..
  10. May 16, 2008 at 10:08 PM
    CometKat
    Carson City NV
    Alright, so here is another obscure question. Is the OEM spare the same for the alloy equipped Tacoma and the steel wheel equipped Tacoma or is it different to accommodate the different type of lug nuts?
  11. May 23, 2008 at 5:38 PM
    CometKat
    Carson City NV
    Let me try another question. For those of you who have the factory TRD off-road wheels do you have a steel rim for a spare or another factory alloy? I know some of the 4runners actually have another aluminum wheel as a spare.
  12. May 23, 2008 at 6:05 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    CometKat, not only is this not a dumb question, but I'm gonna rep you for asking it. I dunno about the 2nd gen trucks, but my 02 TRD had 4 alloys and a steel spare. I've never used the spare, but I have to assume that the shank lug nuts from the alloys also worked with the steel spare. Well, now, I have aftermarket steel wheels with acorn lug nuts. I sold my stock alloys and the original lug nuts with them. Your question has brought to my attention the possibillity that the new lug nuts won't work with my old spare.
  13. May 23, 2008 at 6:29 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    My 05 has a steel spare. I am going to assume that if I get a flat and need to put the steel one on, the alloy nuts that I have WILL tighten up the steel wheel. I didn't get 6 extra lugnuts when I bought my truck. Or maybe I was supposed to?
  14. May 23, 2008 at 7:51 PM
    CometKat
    Carson City NV
    After installing my new TRD off-road wheels using the proper alloy nuts, I don’t think using the nuts off the steel wheel would be a good idea. The alloy wheels are not going to fall off the truck but the interface of the acorn nut to the alloy wheel is not correct.
  15. May 28, 2008 at 7:09 AM
    m&m1951
    m&m1951 Member
    west virginia
    2012, reg.cab,4x4, auto
    I am in the same position looking for some chrome lugs to use on new factory alloys I have coming. Does anyone know if the shouldered Toyota chrome lug is vehicle or wheel specific--or do they fit most wheels and vehicles. I see generic lugs for Toyota/Lexus on ebay, but do not know if they will work with the alloy wheels I have coming. Size wise they are correct--1.5x12mm.
  16. Oct 21, 2008 at 12:31 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    My 07 4X4 Taco has alloy 17-inch OEM alloy wheels with shank-style lugs. However, my OEM spare is a steelie wheel with acorn-style holes. A close inspection of the shank-style OEM lugs reveals an acorn cut on the lug ends, but only a paltry 1/8" contact surface. In other words they will hold the spare for a temp period.
    Some alloy wheels are set up for acorn-style lugs; so, you have to take a close look at the wheel lug cut-outs. If you see a 45 degree angle, they will be set up for acorns. A flat surface (as if someone drilled a hole right through) will require shank-style lugs. The shank length must not be longer than the thickness of the wheel where the lug goes through; otherwise, the lug will contact the rotor/wheel surface without gripping the wheel.
  17. Nov 15, 2009 at 9:47 AM
    mltitlntd
    mltitlntd Well-Known Member
    Steven
    New Orleans, La
    99 Tacoma 3.4 V6 4WD SR5
    None
    wondering is anyone knows where to get lugs for alloys for my Taco outside of Toyota. Hate to pay $60 for them. Perhaps someone has the specs?
    Thanks!
    S~
  18. Nov 15, 2009 at 10:48 AM
    mltitlntd
    Steven
    New Orleans, La
    None
    Based on the posts in this thread, I feel I should be running the "short shank" lug nuts on the alloys that came with the SR5 package on my 99 Tacoma 4WD. However, the truck currently has the acorn type. It appears that the wheels are made to accommodate these type nuts, but I suppose it is possible that the wedge-shaped nuts wallowed out the wheel. I am not the original owner of this truck, but I have never had any trouble with it. I have included a couple of photos showing a lug nut, the wheels and the lug area of the wheel. I would appreciate any knowledgeable input.
    Thanks in advance![​IMG]
  19. Nov 27, 2012 at 6:21 PM
    Steelerdru
    Steelerdru New Member
    Drew
    Pittsburgh
    07 Tacoma 4dr Long bed
    Anyone ever herd of Dorman Lug nuts? Are they any good? as to replace the factory plated junk!
  20. Nov 12, 2015 at 1:06 PM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
