LUG PROBLEM,NEED HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by drizl16, Apr 21, 2012.
  1. Apr 21, 2012 at 7:42 AM
    drizl16
    drizl16 [OP] Well-Known Member
    Derek
    york, PA
    04 xtra cab
    exhaust, k&n intake, painted stock rims, TRD
    So my buddy who has been working as a mechanic for almmost 10 years forgot to tighten my lugnuts back up after he took my tire off. I drove almost 10 miles without any noises etc. when I got home, one of the nuts were missing and the lug stud went back behind the rotor. has anyone else had this happen? All im gonna do is take the caliper and rotor off, pull out the loose stud and replace it. if anyone knows anything else to do lemme know
  2. Apr 21, 2012 at 11:31 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    just do a thorough inspection of everything once you have the caliper and rotor apart. make sure to check all the studs for damage. your plan sounds solid. is your friend going to do this repair for you?:p
  3. Apr 24, 2012 at 5:35 AM
    drizl16
    Derek
    york, PA
    04 xtra cab
    ha. no. im doin it myself, actually i already did it and thank god that nothing else was damaged, I just need a new lug stud and nut
  4. Apr 24, 2012 at 6:37 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    go play the lottery, you have some good luck on your side!
