LugNuts !!!! Help
Discussion in 'Wheels & Tires' started by Mater5, Apr 5, 2013.
  1. Apr 5, 2013 at 8:27 AM
    Mater5
    Mater5 [OP] Active Member
    M
    Ridgecrest Ca
    2012 TRD SPORT
    NONE YET... TO BE CONTINUED ...
    Got the new mat revolvers. Stock lugs won't work on new wheels???? Is this true!!?
  2. Apr 5, 2013 at 8:29 AM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    sometimes they wont depending on the depth and shape on the lug hole. I had to order new lugs for my pro comps. Some rims have an acorn shape and some have a flat bottom so it really depends on which ones come on the rims you got.
  3. Apr 5, 2013 at 12:43 PM
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    Where did you order your lugnuts from?
    I need a set of the flat bottom ones since the Acorn shaped ones i have wont sit properly with my "new" steelies
