Lugnuts not the same size on my truck
Discussion in 'Wheels & Tires' started by CNRIII, Nov 30, 2014.
  1. Nov 30, 2014 at 2:25 PM
    CNRIII
    CNRIII [OP] Member
    I have a '13 V6 SR5 taco. I changed the oil about 3 weeks ago. Due to my crazy work schedule I can only do a little at a time on my vehicle, so I held off on rotating the tires and changing the air filter. After finally getting some time in my schedule to do the work, I get everything set to rotate the tires.
    On the front drivers side I start to crack the all the lug nuts. When I get to the last one the lug wrench won't secure properly on the last bolt. I'm using a 4 way wrench, so I put it down and go the factory jack kit and pull out that lug wrench. It's a no go.
    I look at dimensions on the 4 way lug wrench and it says 22mm. So I go to my socket set and grab a 21mm socket. It doesn't fit. So the 22mm is too big and the 21mm is too small.
    What am I not doing right here?
    Also, my 25k complementary service at the dealer expired in October. On all their paperwork it says they rotated the tires. How did they manage to get the tire off and I can't? Unless they just BS'd me.
    Any help would sure be appreciated.
  2. Dec 15, 2014 at 6:14 AM
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    I did a search and this came up....did you ever come up with a solution? My front drivers side has the same issue....21mm is too small and 22mm is too big. Thought at first that it was rounded so I started to file it down a bit but it's definitely not the same size at all. Gave up....just going to get an extractor I think.
  3. Jan 12, 2015 at 10:10 AM
    CNRIII
    CNRIII [OP] Member
  4. Jan 12, 2015 at 10:20 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Interesting. Be sure that you get them all the same. Would suck to be on the side of the road with a flat you can't change because one lug nut is different.
  5. Jan 13, 2015 at 9:39 AM
    CNRIII
    CNRIII [OP] Member
    Good point.
  6. Jan 13, 2015 at 8:28 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Are these on the factory steel wheels with the horrible plastic center cap?
  7. Jan 14, 2015 at 9:08 AM
    CNRIII
    CNRIII [OP] Member
  8. Jan 15, 2015 at 6:29 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    They seem prone to getting buggered up, possibly the dealer messed up one nut while doing the rotation...?
  9. Jan 15, 2015 at 11:52 AM
    Maticuno
    2011 Suburban 2500
    I had this issue when I first tried to rotate the tires on my work Tacoma. The problem is that the plastic center cap sometimes sits every so slightly off center from the bolt holes that when you try to put the impact socket on it it will bind up, making it seem like the socket is too small. Get it lined up and give it a good push, it will slip on.
  10. Jan 16, 2015 at 9:06 AM
    CNRIII
    CNRIII [OP] Member
    Thanks!
  11. Jan 17, 2015 at 8:35 AM
    Maticuno
    2011 Suburban 2500
    Just to clarify, the 21mm is the size of the socket you need. A deep impact socket is preferable, but can also cause the binding issue I mentioned due to the thicker socket wall. A standard 21mm (non-impact) will likely fit better due to the thinner wall. Just don't use it with an impact gun.
