Lugs Rusting, Nuts stuck
Discussion in 'Wheels & Tires' started by SubFrozen, Sep 27, 2010.
  1. Sep 27, 2010 at 10:49 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Dealership tried to swap tires for me on my Tacoma, called me and told me 4-6 hours to drill out the locking nuts because they are rusted to the bolts and nothing they have tried will get them off.
    I'm at 55k miles on the truck, purchased it a year ago from the dealership with the same tires and rims that are currently on it. Took it to them a month ago and asked for an oil change and tire rotation, they told me good to go and I left. Turns out they didn't do a rotation this time, or any time I have it in to them, due to not having a key (mine disappeared when they were replacing the engine).
    What are my options to getting these off? Do I damage the rims by trying to break them off?
  2. Sep 27, 2010 at 10:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had a similar issue with locking lug nuts a while back. Pepboys figured out how to get them off though. If they're rusted on to the point they won't budge, I'm not sure what you're options are. I'd try penetrating oil but it might be tough to apply it. If you snap the bolts, you do run the risk of damaging the rims when the wrench lets go. You can try to protect them with a cover of some sort but it'll be a crapshoot. You can try heat and a hammer. You heat up the lug nut and tap it with a hammer and try to turn it with a wrench. Key word, TAP! You need to be careful with the heat since they're mounted on the truck also so if you're not comfortable with a torch, don't try it. Last option, wrench with a long cheater bar (wrench handle extension, metal pipe works well). If you do this, be prepared for some broken bolts.
  3. Sep 27, 2010 at 11:08 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Still better than these nuts being stuck...
  4. Sep 27, 2010 at 11:18 AM
    Pugga
    Massachusetts
    :rofl:
    Way to keep things in perspective!
  5. Sep 27, 2010 at 11:33 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
  6. Sep 27, 2010 at 11:34 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    find a crapsman 12 point socket and hammer it on the lug, apply impact gun and done then hammer off the 12 point socket
  7. Sep 27, 2010 at 12:10 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
