Luk clutch plate springs
Discussion in 'Technical Chat' started by Beverford269, Sep 29, 2023.
  1. Sep 29, 2023 at 11:15 PM
    Beverford269
    Beverford269 [OP] New Member
    1998 Toyota Tacoma TRD
    Installing a luk clutch and noticed two of the four springs have a smaller spring inside. Is that normal or should the springs that are inside the larger springs be all the same size. Thanks in advance any help would be appreciated
  2. Sep 30, 2023 at 10:04 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I've installed LUK clutches like that and they've been good as gold
  3. Sep 30, 2023 at 7:57 PM
    Beverford269
    Thanks for the heads up
  4. Sep 30, 2023 at 8:47 PM
    joba27n
    Nolan
    Alberta
    Sorry I can't provide more info. My best guess is to eliminate various order spring forces in a wider range. Same concept as two different springs for dual valve spring setups except with the clutch disk being one assembly, more variation of springs can be used without negatively impacting performance so long as they're 180* opposed which you stated they are.
