LUK stock flywheel
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by rheath08, May 5, 2020.
  1. May 5, 2020 at 7:51 PM
    rheath08
    rheath08 [OP] Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Luk flywheel stock replacement $40 local pick up. It's 31 lbs, not worth shipping.
    I married my tacoma likes this.
  2. May 7, 2020 at 4:35 PM
    rheath08
    Russell
    Bakersfield, CA
  3. May 8, 2020 at 8:05 PM
    MikeyMosin
    MikeyMosin Well-Known Member
    Mikey
    CT
    2nd Gen Access Cab
    AFE CAI, AFE Cat Back, leveling kit, 4runner trail edition rims, pioneer avh 4500nex, kicker 6x9's, tacoma beast headlights, knock off TRD pro grille, Pelfreybuilt Front bumper, Baja Designs Squadron Sport Amber fogs with anytime mod, softoper (sometimes), solid fold 2.0 (sometimes)mevotech ttx lower ball joints and sway bar end links. BAMF LCA skids, Whiteline LCA Bushings, badlands 12000lb winch, SOS weld on winch plates,
    where are you located?
  4. May 8, 2020 at 8:09 PM
    rheath08
    Russell
    Bakersfield, CA
    Bakersfield, ca
  5. May 8, 2020 at 8:10 PM
    MikeyMosin
    Mikey
    CT
    2nd Gen Access Cab
    sorry man Im in CT, any idea how much to ship the molle panel?
  6. May 8, 2020 at 9:47 PM
    rheath08
    Russell
    Bakersfield, CA
    I feel you on that.
  7. May 11, 2020 at 1:49 PM
    rheath08
    Russell
    Bakersfield, CA
  8. May 12, 2020 at 10:04 AM
    mikeymorra
    mikeymorra Well-Known Member
    Mikey
    Solana Beach Ca.
    Toyota Enthusiast current Rig 2015 DCSB
    Flux Capacitor,10,000 Jigawatts,Fully Pimped.
    will that Molle panel fit a DC??or only access??
    im in San Diego
  9. May 12, 2020 at 10:06 AM
    rheath08
    Russell
    Bakersfield, CA
  10. May 13, 2020 at 7:58 AM
    mikeymorra
    Mikey
    Solana Beach Ca.
    Russell I'll do some research and see if I can use that panel..thanks man.
    rheath08[OP] likes this.
  11. May 14, 2020 at 6:45 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  12. May 15, 2020 at 4:09 AM
    mikeymorra
    Mikey
    Solana Beach Ca.
    rheath08[QUOTED][OP] likes this.
  13. May 17, 2020 at 9:17 AM
    battdoc
    battdoc Well-Known Member
    Nirbhai
    2017 Quick Sand Tacoma TRD Off Road
    I'll take the panel, sent you a PM.
    Thanks
  14. May 27, 2020 at 7:15 PM
    rheath08
    Russell
    Bakersfield, CA
  15. May 27, 2020 at 10:36 PM
    Smiley174
    Smiley174 Active Member
    2005 Toyota Tacoma EXT CAB
    what is the purpose of it?
  16. May 28, 2020 at 7:00 AM
    rheath08
    Russell
    Bakersfield, CA
    The sleeve goes over the aluminum quill of the transmission to repair or prevent damage. The stock quill is part of the hell housing. The intent was to help with squeaky or chirping throwout bearings.
    A throwout bearing will need to be over sized or the center bore will need to be enlarged for proper clearance on the new sleeve. Urd sells new bearing by them self's.
  17. Jun 1, 2020 at 8:53 PM
    pm321
    pm321 Well-Known Member
    Price for sleeve and bearing?
  18. Jun 1, 2020 at 8:57 PM
    rheath08
    Russell
    Bakersfield, CA
    @pm321 Well hell..I can't believe I missed pricing it. I'll put it in a flat rate box, so $40 shipped. I'll toss in the brass connector so if you want to bypass the stock accumulator you can.
  19. Jun 1, 2020 at 8:59 PM
    pm321
    I’ll take it. PM incoming
