Lumber rack compatibility 1st gen vs. 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cabsav214, Apr 30, 2011.
  1. Apr 30, 2011 at 10:07 PM
    cabsav214
    cabsav214 [OP] Active Member
    NOR CAL
    08 DC 4x4
    I have 2006 access cab with a shell, I am looking to put a lumber rack over the shell but the only ones I can find are for a 1st gen.
    Will a 1st Gen lumber rack fit a 2nd Gen truck?
  2. Apr 30, 2011 at 10:10 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    No it probably wont. The 2nd gen has a wider bed and much different bed rail setup vs a 1st gen.
  3. May 2, 2011 at 10:39 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    The problem is not whether you can mod it to fit , but how you intend to fasten it to the composite bed .
  4. May 2, 2011 at 11:02 AM
    OZ-T
    Peter North
    British Columbia
    Bolts down through the top of the bedside does not seem like a reliable connection , sorry .
    Good info on the subject here
    http://www.tacomaworld.com/forum/showthread.php?p=1209712
  5. May 2, 2011 at 1:17 PM
    OZ-T
    Peter North
    British Columbia
    Whatever .
    OP , I provided the link above so you would be aware that you may need to do some alterations to the rack to both make it fit and to mount it .
    Good luck .
