Lumber storage rack
Discussion in 'Garage / Workshop' started by kris77, Apr 28, 2009.
  1. Apr 28, 2009 at 6:11 PM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    For those of you who do some woodworking...
    Here is a great way to store your lumber in your workshop or garage...
    Mine is only 2 shelves high but you can make it floor to ceiling...
    12" between shelves. 12" ceiling to top shelf.
    3/8 lag bolts attached to the wall.
    4 inch blocks every 8 inches. secured by 1/2" plywood on the side. Shelves are angled up at 5-7 degrees so they will be level when weight is applied. The backs of the arms that touch the wall are also angled at 5 degrees so it sits in the support flat against the wall. Pretty strong. Im about 215lbs 220lbs and I can do chin ups on 2 of the 2x4 "arms" sticking out...So they will hold quite a bit of weight. I think I made the "arms" 14" maybe 16". I wouldnt go any longer than that...18" would be pushing it I would think...
    Hope this helps somebody...
  2. Apr 28, 2009 at 6:28 PM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    good idea. Very nice worksmanship.
    I need to build something in my garage, but I lucked out with unfinished walls.
  3. Apr 28, 2009 at 6:32 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    I'm going to choose to have half my garage unfinished. So easy to make mounting supports off the existing framing.
