LunarRockV's Trail Edition Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LunarRockV, Mar 30, 2022.
  1. Apr 10, 2022 at 7:23 AM
    #61
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Looking good OP :thumbsup:
  2. Apr 10, 2022 at 11:46 AM
    #62
    LunarRockV
    LunarRockV [OP] Well-Known Member
    Kyle
    2022 Lunar Rock SR5 Trail Tacoma
    I might be biased but I definitely agree with you!
  3. Apr 10, 2022 at 11:47 AM
    #63
    LunarRockV
    Kyle
    Thank you I appreciate it :cheers:
    Road_Warrior[QUOTED] likes this.
  4. Apr 10, 2022 at 11:47 AM
    #64
    LunarRockV
    Kyle
    Thank you!
    71tattooguy[QUOTED] likes this.
  5. Apr 12, 2022 at 5:47 PM
    #65
    LunarRockV
    Kyle
    OEM Black Exhaust Tip installed, also I decided to throw in the custom switch panel and auxbeam switch. Still have to install the auxbeam fuse block and connect my lights to it, but I wanted to see how it looks and feels in that position. The extra switch space will hopefully be for the MESO Puddle Pod switch, assuming I'm able to buy one on the next drop
    hunter5150 likes this.
  6. Apr 13, 2022 at 3:59 PM
    #66
    LunarRockV
    Kyle
    I finally got around to installing VLED's in the visors
  7. Apr 15, 2022 at 10:57 AM
    #67
    LunarRockV
    Kyle
    This was an absolute bitch to fit due to my bed rack and bed molle panels. I still have to add some extra weather stripping on the sides but I am very happy with how it came out and that it's actually functional
    malatx likes this.
  8. Apr 15, 2022 at 11:05 AM
    #68
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    did you have to mod the tonneau cover or it's designed to work with bed racks like yours?
  9. Apr 15, 2022 at 12:03 PM
    #69
    LunarRockV
    Kyle
    It's not designed to work with bed racks, but I looked at a lot of different tonneau covers trying to find one that I thought might work. I bought a cheap tri fold cover that I was going to modify but the way it mounts would never work with a bed rack so now it's collecting dust in my garage lol. I did not have to modify this cover at all but I will have to add some foam weather stripping on the bed rails between the bed rack Mounts because there is an 1/8" gap. I will update with pictures when I do that
  10. Apr 20, 2022 at 12:10 PM
    #70
    LunarRockV
    Kyle
    Raptor lights, Remote Start, s&b Intake and door sill guards installed
  11. Apr 26, 2022 at 2:11 PM
    #71
    LunarRockV
    Kyle
    Auxbeam install, custom harness for fog lights and rewired raptor lights to the auxbeam. I still want to get a longer power wire so I can mount the inline fuse better, but im happy with how clean I was able to install it. I have OCD and seeing people with auxbeam/switchpro have a rats nest of wires, or mounting the fuse box onto the lid of the factory fuse box bothers me lol. Also, I was conflicted about which fuse to tap to power the auxbeam controller, since I had already tapped INJ for the morimoto headlights and raptor lights until I realized that since I have an sr5, I don't need to add power for the drl's. So I removed the morimoto fuse tap, drls still work fine and now INJ is only tapped to power the controller
  12. May 20, 2022 at 1:15 PM
    #72
    LunarRockV
    Kyle
    Finally got around to installing the 41" nilight light bar and wiring it to the auxbeam. Man that thing is bright!
  13. Jun 10, 2022 at 9:02 PM
    #73
    LunarRockV
    Kyle
    Not sure why these yellow Ditch lights look green but they are crazy bright and I love them
    Polythemus likes this.
  14. Oct 7, 2022 at 1:29 PM
    #74
    DAT84
    DAT84 Member
    Dave
    2021 Tacoma SR5 Trail Edition
    Just came across your build, and I'm in love. I have a 2021 T/E and if I would have known 22/23 had lunar rock, locking diff, and the bronze rims, I would have waited. It is what it is though. You mentioned they're lifted slightly over the 2021s. Do you know if the suspension is different, or is it a spacer?
    Also, do you ever find yourself yearning for a larger rim/tire? I tracked down a set at a dealer local to me, and it's REALLY tempting to jump on them. Want a slightly larger tire and slightly more aggressive tread than the Goodyears though. [​IMG]
    RvQOOaqblAnJdD_K4xlr_4Hx6vxoSiz7aJ9PvFbQ_fe4e7d6038c7a8f2ee49ae6a24147c160160b890.jpg
  15. Mar 20, 2024 at 7:31 PM
    #75
    Polythemus
    Polythemus Well-Known Member
    B.C. Canada
    2023 MGM Tacoma Trail Edition
    Toyo Open Country 265 75 r16 tires FN Countersteer Type X, 16x8, 0 offset Front clip PPF, ceramic coated.
    Ive been following this thread for a while now. That's quite the build you have there. Nice work! :)
    I Just put AT tires on mine, Toyo open country AT3s, stock size for now. I find they make the truck look more aggressive. Handles the corners a bit better too.
    I Might go up to 265/75/r16 once i wear these ones out.
  16. Mar 21, 2024 at 7:13 AM
    #76
    YotaHead858
    YotaHead858 Well-Known Member
    San Diego, CA
    2023 TRD OR
    King Shocks Camburg UCA's
    Sweet build OP, Lunar Rock and bronze wheels are my favorite combo.
