Lunch break & AC running?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_dee151, Jul 10, 2023.
  1. Jul 10, 2023 at 6:13 AM
    TRD_dee151
    TRD_dee151 [OP] Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    For my lunch I always go sit in my truck and eat & watch youtube it's summer time here in Oregon, and I was curious if I run my truck for less then 30 mins just for AC so I can stay cool, will this effect my truck in anyway? Since it's just in Idle in Park with AC running and truck turn on?
  2. Jul 10, 2023 at 6:17 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Just running in idle uses surprisingly little gas. Numbers I’ve seen .3 to .4 gal an hour
  3. Jul 10, 2023 at 6:19 AM
    Chastaco
    Chastaco Well-Known Member
    2020 ORDCSB Cement 4x4 Auto
    I hope not because I do this on and off all day one or two days a week in the hot South Carolina summer.
  4. Jul 10, 2023 at 6:24 AM
    Tacospike
    Two Trucks
  5. Jul 10, 2023 at 6:26 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I been doing it for a long time both winter and summer. It has to add to wear engine fuel pump etc but I don’t care! Heat and AC I do care.
    Can’t say it’s done much damage or not?
  6. Jul 10, 2023 at 6:28 AM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    I think you'll be fine
  7. Jul 10, 2023 at 6:31 AM
    epluribusunom
    epluribusunom Well-Known Member
    Luke
    '16 White SR5 4x4
    You bought a Taco brother, run it and let it surprise you with how well it holds up. Also.... it's affect* :)
    Gfenza89 likes this.
  8. Jul 10, 2023 at 6:45 AM
    lbhsbz
    lbhsbz Well-Known Member
    Keep an eye on your temp gauge…even with an electric fan, on real hot days it might have insufficient flow across the cooling stack sitting there at idle to properly cool the engine…
  9. Jul 10, 2023 at 6:56 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
  10. Jul 10, 2023 at 6:58 AM
    Tacospike
    Two Trucks
    Central TX.
    maybe for some. works for me just having a breeze even with heat and humidity.
    OBXPaul likes this.
  11. Jul 10, 2023 at 7:12 AM
    TRD_dee151
    Oregon
    Ok think I'll keep running it
  12. Jul 10, 2023 at 7:20 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Think cop cars etc. Yes you get zero MPG and the AC does jack the idle speed.
  13. Jul 10, 2023 at 7:29 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Toyota has a tsb out since 2005-2023 model years to install an electric cooling fan that bolts to the rad support. It helps to keep the a/c blowing cold in above 100 degrees at idle. I would imagine it also lowers engine temperature too. Problem is Toyota will only install it under warranty if your trucks a/c stops blowing cool air at idle . Not every tacoma is affected for some reason or other. You could always just pay out of pocket and have the dealer install the tsb fan kit for peace of mind.
  14. Jul 10, 2023 at 7:31 AM
    TRD_dee151
    Oregon
    Whats a TSB Fan Kit? Just curious
  15. Jul 10, 2023 at 7:32 AM
    TRD_dee151
    Oregon
    This is the only thing I am concerned about ....
  16. Jul 10, 2023 at 7:38 AM
    Gfenza89
    I’m sorry I don’t have the tsb number on hand but you can google it up and you’ll find it
  17. Jul 10, 2023 at 7:39 AM
    Gfenza89
    It won’t hurt anything as long as the engine stays within temperature range keep an eye on temp gauge make sure it’s centered. These trucks have huge radiators and the clutch fan is pretty massive. The owners Manuel mentions nothing it terms of idling in high heat as far as I know
  18. Jul 10, 2023 at 7:45 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I do it all the time while waiting for my daughters dance class to finish. Winter its the heat, summer its the AC. Never had a issue.
    RIX TUX, TRD_dee151[OP] and Gfenza89 like this.
  19. Jul 10, 2023 at 7:49 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Ahomeofbones and Gfenza89 like this.
  20. Jul 10, 2023 at 7:58 AM
    Gfenza89
