"Lunchbox" Locker In LSD Rear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HolyHandGrenade, Dec 15, 2014.
  1. Dec 15, 2014 at 6:33 AM
    HolyHandGrenade
    HolyHandGrenade [OP] NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Alright, so, I've been searching and searching locker threads. I think I now have more questions than when I started...
    I have a 2013 TRD Sport. I want to put a locker in the rear. I already see that ARB is the locker of choice, so let's get that out of the way...
    What I want to know is, can I put a lunchbox style locker in the LSD rear that came with my Sport without setting gears and such like in the open diff? If no, than I'll go another route.
    Thank you
  2. Dec 15, 2014 at 6:40 AM
    0psi
    0psi Well-Known Member
    Tommy
    Westminster/glen burnie Maryland
    Color match handles,sport hood,fx-r retrofit,fog light any time,eclipse avn726e
    You have an an open diff so all you have to do is set backlash as long as you use your original carrier.
  3. Dec 15, 2014 at 6:44 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    OK, thank you. That's what I'm looking for.
  4. Dec 15, 2014 at 6:48 AM
    0psi
    Tommy
    No problem.Its really easy I do it often.
  5. Dec 15, 2014 at 6:54 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    After all of that searching, and finally just asking, I just stumbled across the answer. Lol!
    I didn't realize the LSD on these trucks was accomplished using the brakes. So, it's just an open diff with simulated LSD? Good for me I guess.
  6. Dec 15, 2014 at 7:02 AM
    0psi
    Tommy
    Ive always wonder if having a locker with vsc if you could ever get in a situation where the truck was trying to stop one rear wheel while the locker was still engaged what would happen.
  7. Dec 15, 2014 at 7:05 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Didn't think of that.
  8. Dec 15, 2014 at 7:09 AM
    0psi
    Tommy
    Yea I don't know but always wonded.
  9. Dec 15, 2014 at 8:33 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if the locker was engaged, there wouldnt be any difference in rotation between the two tires and the brakes would not be applied.
    OP you might want to look at the TruTrac ... its a torsen LSD that seems to do pretty well.
    That stated. Add this to another case of TRD OffRoad stock elocker envy. :D
  10. Dec 15, 2014 at 8:41 AM
    0psi
    Tommy
  11. Dec 15, 2014 at 8:46 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Lol! Thank you...
  12. Dec 15, 2014 at 9:01 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
  13. Dec 15, 2014 at 9:02 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    They got me with that too when I bought my '13 sport. Turns out the last mechanical limited slip was in the '09s.
  14. Dec 15, 2014 at 9:10 AM
    Taco'09
    Taco'09 Well-Known Member
    ^^ Actually '08, but who's counting we get the idea:)
  15. Dec 15, 2014 at 10:18 AM
    nd4spdbh
    SoCal
    The system would try and brake the tires and both would stop or slow down, nothing wrong there but it might not yeild the desired effect.
  16. Dec 15, 2014 at 10:34 AM
    0psi
    Tommy
    Thats what I thought it would do.so your slide might turn into a doughnut.
  17. Dec 15, 2014 at 10:38 AM
    33yrsoftoys
    joel
    mid Michigan
    Or, worse yet, a friggin tree! ;)
  18. Dec 15, 2014 at 11:13 AM
    nd4spdbh
    SoCal
    but its still an LSD (unless your talking bout a auto locker) so wheels can spin at different rates at some point.
  19. Dec 15, 2014 at 11:35 AM
    0psi
    Tommy
    Im talking about my experience with an Detroit ez-locker (lunchbox locker that the op asked about) that it does not lock and unlock when it should.mine I could drift through a turn and it would only unlock it I turned really sharp.It would lock and unlock so hard it would scare you some times.somtimes I could be a half a mile down the road after my turn and I let off the gas and it would unlock with a pop.so I think a situation could arise where it would be locked in a slide.
  20. Dec 15, 2014 at 11:40 AM
    nd4spdbh
    SoCal
    yup.... thats the downside of those style of auto lockers. Very prone to spinning an inside tire in a turn then going CLUNK locking and next thing you know you are in a drift.
    This is why you dont find them on production vehicles for the most part.... outside of the Eaton G80 found on chevy's which actually does a DAMN good job i loved mine in my 2500HD (about the only thing i liked on that truck) But it would only engage at ~ 5mph or less.
