Lunge when Stopped
Discussion in '2nd Gen. Tacomas (2005-2015)' started by argm31i, Oct 16, 2007.
  1. Oct 16, 2007 at 10:01 AM
    argm31i
    argm31i [OP] Well-Known Member
    I have seen some digressions on a couple of other threads about the truck lunging when stopped.
    I too have noticed this in my truck, and I wanted to start a whole new thread dedicated to that.
    I'd just like to know if anybody else has seen this, does it go away eventually, and if you've talked to Toyota, what was their response?
    Thanks.
  2. Oct 16, 2007 at 10:16 AM
    GTiVR6r
    GTiVR6r Big Cat Chew Toy
    Carpentersville, IL
    07 Tacoma Access Cab 2.7L Impulse Red
    Can you describe the symptoms?
    Coming to a complete stop? Gentel pedal pressure or hard?
    While standing stopped? Does it pulsate?
    More info please.
  3. Oct 16, 2007 at 10:26 AM
    argm31i
    This only happens when I'm already stopped (as in at a red light, etc.), and I have the brake applied fully to remain stopped.
    All of a sudden, there is a lunge which actually feels like someone bumped into your rear bumper at a very low speed. 90% of the time, I'll actually look back to make sure this didn't happen.
    I've heard on here that some people feel this only when the AC compressor is on, but I've not done any real testing to see if it is limited to when it's on in my truck.
  4. Oct 16, 2007 at 10:43 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Here's my theory...the lunge is a by-product of the engine load increasing. When the fan or compressor kicks in, the engine idle is too low to support the load. So, the engine idle speed is increased to supply enough juice to the electrical system.
  5. Oct 16, 2007 at 11:11 AM
    GTiVR6r
    Carpentersville, IL
    I have noticed a slight idel increase when the AC kicks in or the evap thingy
    opens to vent off the gas tank fumes. My GTi used to do this.
    But, RPMs never jumped up so much to make the car or truck want to lunge.
  6. Oct 16, 2007 at 12:24 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Not to worry. It'll go away. It happened to mine when new. It happens intermittently and the cause is the prop shaft not returning into place smoothly upon breaking. It does so a little late and makes the truck lunge. The only remedy is to lube the shaft which Toyota did and the problem went away. Talk to the chief mechanic at the dealership.
  7. Oct 16, 2007 at 12:43 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I have the lunge too but i never noticed it till i read about it on this site and started looking for it. It doesnt bother me enough to do anything about it.
    Themaster: are there any negative long term affects if you dont get this taken care of?
  8. Oct 16, 2007 at 4:46 PM
    720 Member
    Tennessee
    1988 Toyota Truck 4x4 V6 manual (reg cab)
  9. Oct 22, 2007 at 7:45 PM
    Terras
    Terras Member
    I have an 07 Access Cab. On a downhill or flat surface I do not see this much....But if I stop on an incline (so I am not really pushing on the brake that hard) and the AC is on....bingo, when the compressor cycles I feel a slight lurch. It is just like someone very very slightly bumping into you. My truck actually only moves a few inches at best cause the pads do take a better bite, but it is spooky till you know what is really going on
    Just my $0.02
    T
  10. Oct 22, 2007 at 7:49 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    mine still does it at almost 23k miles...so i dont think it has anything to do w/ break in period...but i think its that the brake is barely pushed enough to make the truck sit there and when the a/c pops on it kicks that engine up and bumps it...i think thats all.
  11. Oct 23, 2007 at 5:56 AM
    argm31i
    That sounds like a plausible explanation...and yes, it is extremely spooky at first...
  12. Oct 23, 2007 at 6:26 AM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    Not really. Wear and tare will eventually resolve it. Lube will solve it sooner.
  13. Oct 23, 2007 at 7:28 AM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    I agree with your explaination. The only other thing I can imagine it being is the trany finally kicking into low gear. What I don't understand is why this happens at all. I have had several new vehicles and none of them have done this. My '08 does this too so I'm going to try to make sure I drive around without the AC on and see if it still does it.
  14. Oct 23, 2007 at 7:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The truck is downshifting back into 1st gear.....you'll feel that rpm increase as it downshifts. Our Grand Cherokee we owned did that also.
    It'll feel worse with A/C on because the engine will run a higher rpm with A/C running.
  15. Oct 23, 2007 at 2:09 PM
    CoopersTacoma
    CoopersTacoma Active Member
    2010 Double Cab TRD OffRoad V6 Auto
    ARE CAP
    My truck has done this since day 1. When stopped at stop light with a/c on or defroster on the truck will lunge forward if you don't have the brake pedal pressed firmly...pain in the ass and unsafe.
  16. Oct 23, 2007 at 2:34 PM
    2fiddyf
    2fiddyf Member
    08 Super White DC PreRunner SR5 TRD
    Debadged, window tint,shaved front mud flaps
    I have a new 08' and it does this as well .
  17. Oct 23, 2007 at 8:01 PM
    Terras
    Terras Member
    Yes, reconfirmed today. My issue has nothing to do with the transmisson nor any drive play, shaft "wind-up", or anything that needs to be lubricated.
    I just push slightly harder on the ole brake pedal and viola.....no more slight lurch when the compressor kicks in. Without the compressor operating it never does it.
    I Fully believe it is just a case of re-calibrating me.....ha
    At any rate, if this happens without the compressor cycling...then one of the other issues mentioned may be causing it.
    T
  18. Oct 23, 2007 at 8:05 PM
    prclements
    prclements Active Member
    Columbus, GA
    07 TRD Off-Road DC 4x4 SR5 Tow
    Running boards, bed mat
    I have the same symptom - lunging when at a complete stop. My personal assessment is lazy brake pressure. I'm seeing a special trainer at the gym in order to compensate.
  19. Oct 23, 2007 at 9:39 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I've experienced that lurch too, but haven't diagnosed it. I usually have the radio too loud to hear the compressor. It's starting to bug me. I hope it is as simple as getting used to applying more brake pressure at red lights.
  20. Oct 24, 2007 at 7:55 AM
    nd
    Nate
    Greenville, SC
    haha! I like that! Someone finally owns up and blames themselves instead of the truck or the manufacturer :)
