Lurch forward when auto trans shifts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bfogelma, Jun 23, 2010.
  1. Jun 23, 2010 at 12:02 AM
    bfogelma
    bfogelma [OP] Well-Known Member
    Brandon
    San Diego
    2011 DCSB
    Hello everyone, this i guess is my first real post to the forum here.
    I have a 1996 tacoma 4x4 with the 3.4L and auto trans, and i just purchased it about a month or two ago.
    One problem i have noticed is that when i come to a complete stop and then let off the brake to start going forward again(im assuming when the transmission shifts) there is a lurch. However, this does not happen in between any other gears or any other time i am driving. Could this be as simple as a trans fluid flush or is this an ominous sign of something worse?
    thanks in advance for any input guys
  2. Jun 23, 2010 at 12:05 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    How bad of a lurch? It's normal to move forward after releasing the brakes, but not a fast "lurching" motion. Could be something going on with the torque converter.
  3. Jun 23, 2010 at 8:03 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    What's your idle RPM...?
  4. Jun 23, 2010 at 2:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Does it feel like someone bumped into you?
    Sounds like the dreaded axle wrap. The bump, or lurch as you described it, are the rear leaf springs releasing when you let off the brakes. Do your rear leafs have a negative arch?
    This is very common on 1st gen Tacoma's, especially those equipped with automatic transmissions.
  5. Jun 23, 2010 at 5:07 PM
    747 function > form
    1st Gen.
    Axle wrap...
  6. Jun 23, 2010 at 5:10 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    My 2009 kinda does this. Feels like it has a high idle
  7. Jun 23, 2010 at 5:21 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Damn, Axle Wrap never came up in my research on this truck before. How would one go about diagnosing if they have a wrapped axle? or if they are in near danger of such a thing happening?
  8. Jun 23, 2010 at 5:24 PM
    747 function > form
    1st Gen.
    To be clear, your axle isn't wrapped...your axle is (essentially) wrapping up your rear leaf springs. Remedies I've heard of:
    1. New leafs;
    2. AAL; and,
    3. Traction bar.
    I opted for the traction bar; I'd recommend new leafs (or if you're out of $, the AAL).
  9. Jun 23, 2010 at 5:26 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    try lubing up the shaft especially the yoke part. keep pumping lube till u see the shaft start to move (because there is play). this usually fixes it. or at least minimalizes it
  10. Jun 23, 2010 at 5:31 PM
    747 function > form
    1st Gen.
    What tacobo670 described isn't axle wrap (or the cure therefor). But try it first...lube's cheaper than leafs or traction bar.
  11. Jun 23, 2010 at 5:33 PM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Toms River, NJ
    2007 4x4 Regular Cab
    ive noticed this too in my 00.. Im sorry, but what is axle wrap?
  12. Jun 23, 2010 at 5:35 PM
    747 function > form
    1st Gen.
    Axle wrap looks like this when you stop...
    When you let off the brake and/or accelerate, the leafs "spring" back to their proper position...hence, the "clunk", "thump", or "lurch" you're feeling.
    EDIT: If you "search" for axle wrap on TW, you should try spelling it "axel wrap"...I've seen it spelled that way too.
  13. Jun 23, 2010 at 5:51 PM
    SixtyDashOne
    Toms River, NJ
    cool picture, thank you...
  14. Jun 23, 2010 at 8:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Nice drawing. Did you create that? A picture is worth a thousand words...
  15. Jun 23, 2010 at 8:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    bkieth747's picture of the axle and springs tries to depict the battle of forces between the brakes (which are structurally part of your axle housing) and the momentum (forward energy) of your truck. One of the jobs of the springs is to lock down the axle as it tries to rotate when you apply the brakes to dissipate forward energy. The term "wrap" is really trying to describe the rotation of the axle.
    The phenomenon of axle wrap is common to auto tranny's but also happens on manuals, though to a lesser degree. Hard braking brings out the worst of this.
    The stock Tacoma springs seem to be especially vulnerable to axle wrap.
  16. Jun 23, 2010 at 11:58 PM
    bfogelma
    Brandon
    San Diego
    2011 DCSB
    axle wrap seems like a likely culprit now that i think about it. im planning on putting 5100s all around and a small block in the rear, might just do a AAL at the same time and see if that solves the issue.
    the springs are not negative arch, but they are pretty damn close... so this very well may be the problem
  17. Jun 24, 2010 at 8:19 AM
    747
    747 function > form
    1st Gen.
    No...I can't take credit for that one...google image search for axle wrap.
