luxes build
Discussion in '1st Gen. Builds (1995-2004)' started by higherlux, Aug 16, 2009.
  1. Aug 16, 2009 at 8:14 PM
    higherlux
    higherlux [OP] Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    everyone else has one
    so why not me
    start out with a completely stock (other than the bfg AT ko's, tool box, and 4' firestick anntenna) 1998 toyota 4wd
    no pics of it when i bought it
    first mod was move the cb from just wedged between the seats to under a new pioneer deh-1900mp cd player and a new whip cb anntenna (cuz i broke the firestik :D)
    cost 135$
    next was a class 2 reciever hitch i got from my mom as a birthday present
    it was destroyed on jan 22 09 by a white lincon going under me in my first wreck ever
    drove it around like that for about 6 months intill i got some new 31x10.50xr15 defenity dakota M/T's
    then shortly after that i made a 1/2 inch body lift (front) and 3/8 inch body lift (rear) to help get the tailgate off the rear bumper and to level out the body lines
    wreck 1/22/09 3 car collision lincoln ls rear ended me and pushed me into a 89 ford mustang
    (sorry no pics)
    had a custom black SR5 decal made
    then bought wheelers type b black powercoated rims (used) cost $150 from tigerfan00
    cont. tomarrow
    ummm what was next??
    oh yea deck plate and rear dif breather mod and valve cover gasket replacement
    then a warn transformer brushgaurd (kinda wish i got a arb instead)
    the next day i skiped school and bought some cheapo 25$ lights for it
    black taillight mod
    ruined the cheapo 25$ lights doing this
    had to drain out all the water and rewire the lights so they will work again
    then i got a package from automatcentral
    55 watt lights, sweet
    installed
    went out and bought 9 cans of black spray paint and scraped the crap off from my frame and painted the frame, wheel wells, rear axle, and front skid plate
    and what paint i had left over i did the BHLM (yes on a 98) and blacked out my corner lamps to mach
    (not shure if i like the BHLM yet i might take it back appart and sand the black off)
    painted the front toyota symbol completely red
    didnt really like it like that so i went red and chrome (much better IMO)
    ***wreck #2
    easy fix for me
    while i had the bumper off i decided to "trim" it up a lil for more ground clearence
    and thats it for now
    will add more when i add more mods to her
    notice somthing new???
    you can also see i blacked out the amber lendses on my corner lamps and tinted my turn signals
    audio upgrade:
    from this
    to this
    and new pioneer 6 1/2 door speakers no pics
    100_1539_8cc0170d3934b2d83256093cc6c78446c5237310.jpg.
    damn
    thats what happens when you forget where the wire goes for the aux plug hot all the time mod
    so i redid it the right way
    don't worry i didn't leave those wires exposed ,thats where the relay was for the aux plugs and it is now the relay for my lights i have on my bumper. (i have 2 switches for them) one switch is the hi-beam switch with the headlight and the other switch wired parallel to the high beam switch so i can run my high-beams without the lights.
    a more up to date pic of my taco:D
    and yes that is a BHLM you see ,and yes it didnt turn out so hot :eek:
    but it's kinda growing on me :)
    OH SNAP!!!!!!!!!
    nah just doing ALOT of body work and painting ;)
    teaser
    it defiantly doesn't look professional but it looks 100X better than it did
    from this
    to this
    and then
    yes i did the cab first and kept it like that for a week because of business and weather and yea those are purple spots on the bed and they were on the cab and pass side door and tailgate
    the paint i used to cover it up did a great job i think any way
    like it?
    CRAP!! :(
    at least it happened on this tire and not one of the new ones
    the other Dakota tire started leaking around the rim the day before , i guess its time for some new tires and a alignment :eek:
    had to rob 2 tires off the 86 (you get a little sneak peek of the freshly painted rims)
    and to cheer myself up i went and did a lil wheelin
    and who says IFS cant flex???
    stuffed
    full droop (actually off the ground)
    MAJOR (and minor) updates
    BIGGEST!!!!!!!!
    lost this crap
    (note my awesome car ramps)
    and on with this (when i picked it up from 07NavyTaco i raced home and put it on which was at like 10pm?)
    it looked like that for a few days until i picked up some bed liner and some new mounting hardware. i took it up to my dads place (pretty much a fully equipped shop) and took it off and bed lined it, reinstalled the winch with grade 8 bolts (you can never overbuild, a great rule to go by ;)),relocate the winch control box on the firewall beside the piper motor, installed my off road lights and fixed the bent flair lead mount.
    also while i was at pops shop i redid the front cross member (for the skid) my first one didn't hold up too well. its just a piece of angle iron bolted to the frame, nothing special, but should be documented.
    new to me power steering pump because i was tired of no power steering:( (thanks yoda1999 )
    new to me 01-04 tacoma tail lights (thanks MMyota)
    rebed lined my tool box
    rebuilt passengers side locking hub (now i need the drivers side done)
    new to me headlights (thank you XxTHe FioLOxX)
    new to me plastic bumper things (thanks jrich44)
    new to me a/c control and cables (junkyard)
    new clutch master cylinder (old one died)
    test fitted the 01 hood and damn it looks good :cool:
    shit i wish it fit that good :(
    no gap
    a good 7/16th gap
    the 86 was a good table though :eek:
  2. Aug 16, 2009 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sweet!
  3. Aug 16, 2009 at 8:17 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    looks like shit sell it and get a gun :p
    jk ;)
  4. Aug 16, 2009 at 8:23 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    :eek:
  5. Aug 16, 2009 at 8:23 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    thanks :D
  6. Aug 16, 2009 at 8:24 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    haha im actualy thinking about gettin a 01 extended cab 4wd soon...my dads job isnt looking too steady
  7. Aug 16, 2009 at 8:25 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    nah screw that
    get a 98 like mine
  8. Aug 16, 2009 at 8:26 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    the dealer has it sitting on the lot right now
  9. Aug 16, 2009 at 8:28 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    well go for it
  10. Aug 16, 2009 at 8:33 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    well only if my dad does get laid off
  11. Aug 16, 2009 at 8:35 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Looks good! :)
  12. Aug 16, 2009 at 8:39 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    but its a cheaper upgrade
    thanks :D
  13. Aug 16, 2009 at 8:40 PM
    Uhaul-n-azz
    Uhaul-n-azz Well-Known Member
    fayetteville,AR
    4Runner Stock
  14. Aug 16, 2009 at 8:40 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    haha i really want it...it would be so pimp
  15. Aug 16, 2009 at 8:42 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    haha thanks :thumbsup:
    se if ur dad will let ya get it anyway
  16. Aug 16, 2009 at 8:43 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    i dont even want to ask
  17. Aug 16, 2009 at 8:46 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    y not?
  18. Aug 16, 2009 at 8:47 PM
    white+Peal
    white+Peal Well-Known Member
    Kris
    Henderson, NV
    08 prerunner
    Magaflow catback exhaust, AEM CAI, front bumper made by famous fabrication, JBA long tube headers, All pro back bumper, BPF raptor style grill, 3' toytech lift
  19. Aug 16, 2009 at 8:47 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    he dosnt want me to even get tires for $200 i have to get good grades:rolleyes:
  20. Aug 16, 2009 at 8:54 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    we get good grades damnit
