Luxo Taco For Sale
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by JordanSmith127, Apr 25, 2016.
  1. Apr 25, 2016 at 9:59 AM
    JordanSmith127
    JordanSmith127 [OP] Jordemo805@yahoo.com
    JORDAN
    SAN LUIS OBISPO & MARIN
    2017 DCSB 4X4 TRD SPORT
    ICON / LSK
    It kills me to do this guys but 2 years ago when I set out to do the full build on this thing i was in a different situation, unfortunately now I don't have time or a need for it and want to offer it up for someone else to enjoy...I by no means need to sell this right away and have no problem sitting on it for awhile but for practical reasons it needs to go up for sale.
    Selling my fully built Toyota Tacoma Pre-Runner. All work done by Dezert Toy Fabrication In Santa Maria, CA. Truck was just finished Mid April. Aside from the motor, steering rack, and transmission all components have been replaced or rebuilt. (water pump, pulleys, belts, spark plugs, thermostat, wheel bearings, brakes, ujoints etc) Truck was built with plans to race class 7100/2000 and can still be driven on the road. All fab work has been 360 MIG welded, primed and painted.
    Full 2” DOM radius bent cab cage tied into both the cab, engine cage, bed cage and frame, seats 4. Black carpet interior and headliner, 2 Layers of 100% coverage Dynamatt, closed cell foam and jute padding in cab and doors for superior sound deadening. Lowrance GPS, Rugged Radio 4 Person 660 intercom with headsets, Kenwood race radio, PA system, 5 channel Lightning audio amp, Memphis audio speakers, Kenwood deck, Audio Mobile 10” subwoofer, custom box, KC red interior dome lights. NRG steering wheel with quick disconnect. Seats are black vinyl Corbeaus with red 5pt 3” Crow harnesses and sewn on pads.
    Complete engine cage made out of 2” and 1.75” DOM with removable headlight/grille portion For easy access to front of the motor/radiator. Shock tower gussets and lower control arm solid mounts/gussets. Solid motor and trans mounts. Electric Trans cooler, 2.25” aluminum Griffin radiator with electric fans, Mean Green H/O alternator, UMP intake system with an inlet made to drain water and feed thru hood louvers, URD performance thermostat, aluminum manifold spacer as well as aluminum overflow tanks for rack and radiator. Bolt on front bumper for easy replacement and access to the front of the motor/rack, full skids al the way past oil pan with drain hole and replaceable nerf bar. JBA long tube headers with O2 sensor harness + extender, Doug Thorley Y-Pipe, Aerochamber muffler.
    Bed cage built off stock frame which has been boxed, and then tied into the cab cage in several locations. 32 gallon Jazz fuel cell wired and ran with 100% OEM Toyota components to pass emissions and keep function of fuel gauge, 320lph high output fuel pump. Hydraulic latch trunk on heims with dual full size spares. Functioning electrical outlet in gas door, removable crush bar, and dual yellow top optimas. Rear axle is a 10.5” 2nd gen. Toyota Tundra axle, custom driveline made with slip yoke, bigger carrier bearing, and yoke flange.
    Front long travel is a one off DTF 6” over race kit bumped and strapped at a smooth 18”. Includes heimmed steering and UCAs, double sheered tie rod mounts, vertical 2” uniballs. Recessed shock mounts to allow a 10” dual rate coilover to fit in stock shock bucket. Rear suspension is the DTF Spring under axle kit, set up with a rear boomerang shackle on Deaver H70 leaff springs, bumped and strapped at a clean 18” without leaff separation. Both front and back LT per corner are running dual limit straps and stainless brake lines.
    Lights and electronics include. The retrofit source D2S retrofit headlight with blacked out housing, LED taillights, Tough Light 20” Ultra 4D LED bars and pods in the valence. Hella HIDs on roof rack, KC dome lights in the cab. Complete sounds system, Rugged radio intercom and race radio. Lowrance GPS, PA system, electric cooling fans. And more! ALL wiring on truck has been solderd and heat shrunk at connections, and then loomed and electrical taped every 12” to keep wiring neat. All wiring has been ran to an SPOD for easy and clean installation. Dual Optima yellow top batteries located in the trunk and a battery selector switch in reach of the driver.
    All parts are new or practically new with very low miles and in perfect working condition. Fiberglass is Fiberwerx at the nose a 1 piece front clip with louvers and at the tail the bedsides are the 6” trophy truck style. Tires are 37” BF Goodrich’s. Wheels are 17” KMC Enduro Beadlocks. All shocks are newly rebuilt Sway-A-Way with the exception of Fox Bumpstops. Vinyl wrap is 3M satin dark grey. Window tint on all 6 windows. Fiberglass is held on with Dsues fasteners and aerocatch latches for a strong, clean, and easy removal. Long travel has been powder coated matte black. ARP extended wheel studs.
    Truck is in great shape, runs flawlessly and in need of a new owner with time to use it.
    Thanks, Jordan.
    SOLD
    image2.jpg image3.jpg image4.jpg image5.jpg image7.jpg image8.jpg image9.jpg image10.jpg image1.jpg
  2. Apr 25, 2016 at 10:02 AM
    JordanSmith127
    JORDAN
    ICON / LSK
    Ill upload more detailed photos off all the small detail and what not in a little bit
  3. Apr 25, 2016 at 10:04 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Holy fuck. My birthday (turn 22) is tomorrow.. I'd snatch this up if i had the cash. :drool:
    GLWS OP, Very clean truck.
  4. Apr 25, 2016 at 10:10 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
  5. Apr 25, 2016 at 12:40 PM
    Mad T
    Mad T Well-Known Member
    Thomas
    Georgia
    Sad to see you having to sell it. This build is one of my favorites! Good luck with the sell man.
  6. Apr 27, 2016 at 9:23 AM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    dude this truck is insane.. if u were closer to NJ, id buy it just on principle
  7. Apr 27, 2016 at 9:29 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
  8. Apr 30, 2016 at 7:36 PM
    JordanSmith127
    JORDAN
    ICON / LSK
  9. Apr 30, 2016 at 7:38 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    That ain't a tacoma that's a trophy truck.
    It's absolutely beautiful sorry you have to part with it.
  10. Apr 30, 2016 at 7:57 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    This deal won't last long folks. Jordan's selling this in California, and this is Tacoma World. We'll start the bidding at $40,000.00! Do I hear $42,000.00! Now $44,000.00! This is a one of a kind rig gentlemen! Now $46,000.00! Can I get $48,000.00?!! Yes or no got to go!!!
  11. May 4, 2016 at 9:37 AM
    336 Well-Known Member
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    such a bad ass truck.
  12. May 4, 2016 at 9:46 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Number of miles on engine & transmission?
  13. May 4, 2016 at 9:58 AM
    JordanSmith127
    JORDAN
    ICON / LSK
    130k
  14. May 4, 2016 at 1:28 PM
    addicus24
    Great looking rig to me. Wish I could buy it.
  15. May 4, 2016 at 10:25 PM
    Idonthaveatoyotatbh
    Idonthaveatoyotatbh New Member
    Austin
    2000 Ford Excursion Limited
    ProComp 10" Lift, Toyo 37x13.50r17lt M/Ts, Insane sound system with 2 12s, two sound stream amps and a pioneer deck. All clean work with Caliraised LED Light bars. 7.3 V8 with a Garrett Turbo and an Edge Platinum 5-mode Programmer.
    Oh man sorry to hear the news. I'm from the SLO area too and I don't think I've ever seen that beauty around town before... hey, if it ever comes down to it where you're lookin for a tricked out family rig with a a 7.3l turbo diesel, hit me up. You got a beautiful rig, glws
  16. May 5, 2016 at 5:09 PM
    jsway9
    jsway9 Ninja
    Monterey CA
    2000 Toyota Tacoma 4x4 TRD SR5
    Front Relentless Bumper Rear Outdoor Logical Swing Out Front King Coilovers Rear Fox Shocks All Pro Expo. Leaf Springs
    Interested...... Might pull the trigger
  17. May 5, 2016 at 5:14 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Dear god......:eek::eek::eek:
    That is quite the rig....
    GLWS, sorry you need to part with that beauty :(
  18. May 7, 2016 at 7:28 PM
    JordanSmith127
    JORDAN
    ICON / LSK
    sold....
    TacoMEDIC likes this.
  19. May 17, 2016 at 10:24 PM
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    nice! what was the color on that truck? was it wrap or paint?
  20. May 22, 2016 at 9:11 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
