M.O.R.E. Balls Out 250 - 3/17/2012
Discussion in 'Southern California' started by mikesdoublecab, Jan 23, 2012.
  1. Mar 21, 2012 at 11:58 AM
    #201
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    That's a lot of work to get done in a month. How are you setting up your bump/strike pad in the rear? And who's doing your frame plating/boxing?
  2. Mar 21, 2012 at 12:02 PM
    #202
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    bump stops will strike the leaf spring on the u-bolt flip plate. The bump can will be notched into the frame.
    My buddy will be doing all the fab work. The rear will take the most time, but it all needs to be cycled together in one go so it all works, not piece by piece.
  3. Mar 21, 2012 at 12:09 PM
    #203
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    ill tag along.
  4. Mar 21, 2012 at 12:11 PM
    #204
    Bobber Bill
    Los Angeles, CA
    Yeww... that's what I figured. I'll probably end up fabbing up some strike pads on risers to go over my U-bolt flip plate. That'll keep the bumps away from the U-bolts and give them more surface area to slam down on
  5. Mar 21, 2012 at 12:16 PM
    #205
    blackhawke88
    SGV, CA
    07 TRD Offroad
    good idea, but properly cycled bump stop should hit the same spot over and over to avoid scrubbing.
  6. Mar 21, 2012 at 12:24 PM
    #206
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    Do you have a welder?!?
  7. Mar 21, 2012 at 12:36 PM
    #207
    Bobber Bill
    Los Angeles, CA
    K then, I'll wait for you and Jen to test that setup before I start chopping my own frame. I'm also concerned with the effective stroke on those bumps with the U-bolts in place. Those things stick out quite a bit, reducing the effective range of the bumps. You could always opt for longer bumps and cut the bolts down closer to the nuts/plate though I suppose.
    And are you guys just gunna cut the frame boxing plates as you go along? or are buying pre-cut pieces?
    No...:spy:
  8. Mar 21, 2012 at 12:41 PM
    #208
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Engage has a frame boxing kit that is all pre cut, but we will see when the time comes. We may just box certain sections of the rear instead of the whole thing, and plate where the shock hoops attach.
    At full bump, as long those bolts dont hit frame, it should be fine, I dont think it will come in contact with the bump stop body or can.
  9. Mar 21, 2012 at 12:45 PM
    #209
    Bobber Bill
    Los Angeles, CA
    Cool beans. Hurry up and git 'r done so I can bootleg it.
    What about the cam tabs and shower towers?
  10. Mar 21, 2012 at 12:46 PM
    #210
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I can't wait for jens rear to get done.. mine will be based off of how it comes out, hurry up and get that shit done:cookiemonster:
  11. Mar 21, 2012 at 12:48 PM
    #211
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Cam tabs may get reinforced down the road, may just solid mount and get heimed uppers down the road.
    Shock tower gussets are a good idea, but wont be that hard to fab during the install process, i should mark it down.
  12. Mar 21, 2012 at 12:50 PM
    #212
    Bobber Bill
    Los Angeles, CA
    Might as well if you're gunna have the front end all tore apart already. Good luck
