M/T Classic Lock Question
Discussion in 'Wheels & Tires' started by 1337Taco, Jun 11, 2010.
  1. Jun 11, 2010 at 5:48 PM
    1337Taco
    1337Taco [OP] Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I'm looking to go a different route with the wheels on my truck and am wondering if these wheels would work for me without rubbing. I searched but couldn't find anything. Thanks for helping.
    http://www.4wheelparts.com/prodDetail.aspx?partNo=M/T468412
    Part Number: M/T468412
    • M/T Classic Lock Wheel
    • 16x8, 6 on 5.5 Bolt Pattern
    • BackSpace 4 in.
    • Max Load= 3100lbs
    • Finish = Polished
    • Hubcentric= Yes
    • Offset = -12 mm
    I'm thinking I might have to get 17's but I really don't want to get new tires.
  2. Jun 11, 2010 at 6:16 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Those will work, but if you want 17's then these will work too.
  3. Jun 11, 2010 at 6:25 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Nope, trying to stay away from 17's because My 285/75/16's have less than 5k miles on them and don't want to buy another set of tires.
    Thanks for the help.
  4. Jun 12, 2010 at 8:37 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Anybody else have any input on this as a second opinion?
  5. Jun 12, 2010 at 10:03 AM
    Incognito
    VA
    Also you should be good on the rubbing with the 4'' backspacing... :)
  6. Jun 12, 2010 at 10:18 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Ok I wasn't sure which way it went because I have 4.5" now and wasn't sure if 4 or 5 would be better. Also the offset always gets me confused. Thanks for the help. What kind of wheels are you running Colton?
  7. Jun 12, 2010 at 10:33 AM
    Incognito
    VA
    Yeah the lower the backspacing, the further the wheels will stick out. Having a wheel with a 4.5-4 backspacing would be somewhat similar to stock wheels with spidertrax spacers IIRC.
    I'm running stock Sport wheels, but I will be replacing them with XD Addicts when the time comes, 4.5'' BS. No problem with the help, feel free to ask if you have any other questions!
