M/T to 5vz-fe mating tips and tricks needed! Asap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ironworker84, Mar 14, 2020.
  1. Mar 30, 2020 at 4:45 PM
    #61
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It almost HAS to be a vacuum leak.
    Edit: A big one
  2. Mar 30, 2020 at 6:03 PM
    #62
    Ironworker84
    Ironworker84 [OP] Well-Known Member
    Eric
    2001 White Tacoma 4X4
    How would I go about looking for that
  3. Mar 30, 2020 at 6:11 PM
    #63
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Listen for a sucking sound.
    Have you checked that the throttle moves freely? And closes completely also?
  4. Mar 30, 2020 at 6:33 PM
    #64
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Sounds like the throttle is stuck to me.
  5. Mar 31, 2020 at 1:55 PM
    #65
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    Did you re-attach that vacuum hoses that go to the vsv's in the engine bay that go to the front diff?
    check all the vacuum hoses since you pulled the motor, and brake booster hose etc... sounds like a very large leak to idle that high.
  6. Mar 31, 2020 at 10:22 PM
    #66
    Ironworker84
    Eric
    Finally finished. Damn! The throttle was stuck open. Now its little nit noid shit I have to go back over and adjust. But it's running. I'm happy with the outcome
    Hooligans likes this.
  7. Apr 1, 2020 at 7:17 AM
    #67
    ssoulssurfer
    ssoulssurfer Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Sorry side question - did you POR15 your frame, or what coating did you use?
    CS_AR[QUOTED] likes this.
  8. Apr 1, 2020 at 10:24 AM
    #68
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    1) Used a wire brush attachment on my electric drill and removed any flaking old paint or any surface rust from gravel rash.
    2) Primed with Rust Oleum a self-etching primer for areas where I removed the old finish.
    3) Painted the outside with Black Gloss Rust Oleum Farm Implement paint.
    The truck has not been or will never be exposed to salt.
  9. Apr 1, 2020 at 10:36 AM
    #69
    ssoulssurfer
    Gotcha thanks, looks nice
  10. Apr 1, 2020 at 11:02 AM
    #70
    Ironworker84
    Eric
    I'm in colorado. So its dry enough here I dont have to worry about undercarriage protection
