m1 leveling strut vs Bilstein 5100 shock????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Section8joe, Dec 22, 2023.
  1. Dec 22, 2023 at 6:29 PM
    Section8joe
    Section8joe [OP] Member
    Joe
    2021 off road
    I'm new to the suspension world and I'm wondering which kit you prefer and why. Any advice will be greatly appreciated.
    M1 leveling strut
    or
    Bilstein 5100
    I'm not doing anything crazy off road. I just want a little better look and I don't want to sacrifice much ride quality.
  2. Dec 22, 2023 at 9:12 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Bilstein 5100 for sure
  3. Dec 22, 2023 at 9:17 PM
    TacoTuesday1
    FL
  4. Dec 23, 2023 at 7:00 AM
    Section8joe
    Joe
    2021 off road
    Sorry for the rookie question but why do you like these over the M1?
    71tattooguy[QUOTED] likes this.
  5. Dec 23, 2023 at 7:05 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    No rookie question at all. Bilstein is tried and true. 5100’s are a great leveling shock. Direct oem replacement as well. Tons of members on here run them as I did a few years ago. You won’t be disappointed.
    Tocamo likes this.
  6. Dec 23, 2023 at 7:36 AM
    02hilux
    Planet: EARTH
    The name says it all, ROUGH
    Tocamo likes this.
  7. Dec 23, 2023 at 7:46 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Bilstein is the Toyota of the shock world! 'nuff said!!
    71tattooguy likes this.
  8. Dec 23, 2023 at 8:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    So just for some clarity as you continue to peruse and consider things..............
    Tacoma's do not have struts, either front or rear. The front has a double wishbone independent suspension supported by a non adjustable coil over shock set up. The rear is a solid axle supported by leaf springs and shocks.
    Shocks of themselves do not determine ride height. The springs do that. The purpose of the shock (also called dampers) is to control the spring oscillation. So you might ask how do something like 5100s, even used with OE springs, create lift? It's because they have choices for the lower spring perch position to mount on the shock body. Compressing the spring by making it shorter on a higher perch creates the lift. Also sometimes referred to as pre load.
    Other points of interest. All vehicles are engineered with some rake for specific purposes. Trucks are more noticeable because it's typically a bit more. Allowing for load in the bed. So when you do a level for looks, you potentially hamper some function, depending on how it's used.
    A suspension lift doesn't create additional clearance at the low point of the vehicle, being the axle lines. Only tire package diameter can increase that. The suspension lift can help with approach and departure angles for off road use.
    A suspension lift doesn't automatically allow for a larger tire package. The literal size of the tire and the specs of the wheel of choice are much more important for that, as well as caster settings in your alignment.
    A good way to lift the front is by selecting a spring rated to do what you want, then the correct damper to control it. Several of our supporting vendors can assist in those choices.
    Yes, you'll hear the word strut tossed about, you'll read it on vendor sites, and the excuse will be 'same thing, different words. You know what we mean'. But if you'll research how a strut attaches to the vehicle you'll find it quite different than our set up.
    Anyway. Hope that helps the 'ole learning curve a bit. Do all your research before you buy, and buy your hardware for how you will use the truck 90% of the time, not for how you might use it someday.
    Best of luck.........
