m8000 what else fits the arb bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mtmudrunner, Feb 9, 2018.
  1. Feb 9, 2018 at 12:25 PM
    mtmudrunner
    mtmudrunner [OP] Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    Looking at different winch options for the arb.
  2. Feb 9, 2018 at 12:42 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I have the smittybilt x2o 10k in my arb. It works, but the freespool lever is in a very tight spot.
  3. Feb 9, 2018 at 5:28 PM
    mtmudrunner
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    Thanks for the info I see 4wheel parts is has the arb bumper for $926 shipped, that is the cheapest I've seen it
  4. Feb 9, 2018 at 5:35 PM
    Pigpen
    Dan
    Northwest Montana
    When the time comes, I'll get the CBI Dakar Rally bumper. Lots of room to get to your winch.
    For now, I'm quite happy being able to carry my winch in the bed of the truck and run it off the front or rear as needed.
    Most winches should fit the ARB. You may need to relocate the control box - which will give you better range on a remote controller, anyway. I've used mine from well over 100 feet away.
    Edit: controller range is advertised as 50 feet
