M8000 Winch, stiff clutch lever
Discussion in 'Off-Roading & Trails' started by Albertataco89, Apr 30, 2014.
  1. Apr 30, 2014 at 7:29 PM
    Albertataco89
    Albertataco89 [OP] Well-Known Member
    Joey
    Alberta
    09BlackLiftedSR5
    Arb winch bumper, M8000 warn winch, 6 inch BDS lift, mayhem wheels, kenwood all around
    Hey guys, I have a M8000 winch which has a very stiff clutch lever. Just wondering if anyone has had this issue before and what to do. Im thinking of just taking it apart and giving it a good grease but not sure what way to go about it?
    Bertw192 likes this.
  2. Apr 30, 2014 at 8:16 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Mine's like that sometimes. But it's a lot harder when I'm too lazy to put some gloves on. It makes a world of a different with gloves
  3. Apr 30, 2014 at 8:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Beside the lever is a socket head screw - remove it, lift the lever out, inspect the o-ring, and clean any corrosion from the bore and lever. Apply some grease to the oring and bore, and reassemble being sure to line up the stub on the lever with the groove in the sliding clutch. That should do it, in a matter of minutes. Of course, if the winch hasn't been disassembled, cleaned and re-greased, it might be the perfect time to do it all at once, but thats a much bigger project.
  4. May 1, 2014 at 10:28 AM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    I had gloves on the problem is I have the winch on the ARB bumper so it's in a pretty tight area to begin with, I would like to be able to turn it with just one finger. My dad's is brand new and his is smooth and even with mine outside the bumper it's impossible to turn
  5. May 1, 2014 at 10:29 AM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    Thanks for the info I will give that a try first
  6. May 1, 2014 at 10:43 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    good info thanks!
    good luck OP. report back with how it goes. maybe I'll get off my lazy ass and do the same lol
  7. May 1, 2014 at 1:03 PM
    Albertataco89
    Joey
    Alberta
    09BlackLiftedSR5
    Just did what you said, the lever moves freely I took the lever off and put come clean flo winch grease inside and put the bolt back in. Turns pretty freely now! You wanna be careful not to over torque the bolt holding the handle in place to whoever may use this thread in the future, I put some lock tight on it and snugged it up but didn't over tighten as it might crack the housing
  8. May 14, 2014 at 9:22 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I'll have to give this a try. Mine has been tight since day 1 and I just assumed that's how WARNs were built.
