MA dealer experience quick review
Discussion in 'North East' started by kingston73, Aug 20, 2012.
  1. Aug 20, 2012 at 6:55 AM
    kingston73
    kingston73 [OP] Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    Just wanted to put this out there for any of you in ma or ri. I recently bought my 09 from bernardi toyota in Framingham. I got a good price and the buying part was relatively easy, but that's about the best I can say for them. I had a question a couple days later and tried calling bernardi, I got a person on the phone who wouldn't answer my question and transferee me to the sales rep who sold me the truck. He didn't answer so I left a message...two days later still no return call so I call again and same exact scenario. I left a second message and here it is two weeks later and I never got a return call. It wasn't an important question but it's just principal of the thing, f'ing return a customers call dammit!
    Then I tried dealing with their service dept. Part of my deal for buying the truck was getting my michelins transferred from old truck to new and the service dept was supposed to have an appt for me. I showed up a few minutes early for my appt and find put they had no record of any appt and had no idea what I was talking about, so I had to wait for service to talk to sales to get it all straight. I then had to wait 4 hours for them to transfer the 4 tires. Finally get it back and go home.
    A few days later I haul my first small load and the springs are sagging. I find the tsb info and make an appt for bernardi to check it out. I drop it off and leave it overnight, wait until 3pm the next day and finally call them to find out what's going on. I get a person who transfers me to the voicemail of the tech who checked me in the previous day so I leave a message and wait an hour. I call back and find out that person isn't even working that day. The person I'm now talking to cant find my records so I have to wait again for him to call me back. He finally gets back to me and tells me they took it for a test drive and everything is fine. I ask them how they load tested it and he doesn't know what I'm talking about, turns out the complaint that was entered was "customer complains of harsh ride", nothing about WHEN LOADED!
    Which brings me to Ira Toyota of Milford. I'm there right now, they listened to my complaint of sagging springs, wrote down all the info and fax number that Toyota corporate gave me when I called them and complained about bernardi, said they will check it out and if they have parts in stock might even be able to start work today and give me a loaner car. I don't know how it'll turn out yet or if I'll get the tsb springs but the overall experience so far has been much better. Ira just seems much more competent.
    I know this is pretty long but hopefully if any of you are local and looking for a dealer to work with this will help you.
  2. Aug 20, 2012 at 7:09 AM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    Saaaweet
    Stealerships....scumbags get ur $ and after that u r on ur own..sorry to hear that.
  3. Aug 20, 2012 at 7:24 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Yep, and there's not much you can do. Noticed you live in Chesapeake, I went to high school down there at Indian river hs. Lived over in plantation lakes near the va beach line.
  4. Aug 20, 2012 at 7:44 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Just a word of caution with Ira of Milford, check their work! Their service reps are great and really do a good job making you feel comfortable with them. When I got an alignment, I tried giving the service rep custom specs and he actually brought me down to talk to the alignment tech to make sure he knew what I wanted. That was great and meant a lot to me. The bad, the alignment tech got the specs I wanted and didn't torque down the LCA bolts (kind of important). I heard a clunk and went under to check it out and found them loose. I make another appt, they apologized, got me right in, and I waited 3 hours for them to do a second alignment... That's where they lost me. They then sent out one of their surveys to find out how they did. I rated them honestly, wrote up what happened, said the reps were great, they messed up the alignment and the new appt took WAY too long especially considering they were fixing their own mistake. No call back, nothing (Prime Toyota in Dedham would always call once their surverys were returned, regardless of good feedback or bad which I always thought was nice).
  5. Aug 20, 2012 at 8:08 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Good to know, thanks. I'm still waiting to find out if they're going to actually do any work or not.
  6. Aug 20, 2012 at 12:28 PM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    I bought my 09 taco from Harr in Worcester and had good experience with them.
    Whatever you do STAY AWAY FROM RTE 44 TOYOTA in Raynham and TOYOTA OF DARTMOUTH obviously in Dartmouth. I would give them to a tie on the worst dealerships ever to deal with.
    Both their service and work was horrid and the reason I had to sell the truck. I had nothing but problems with the truck after they got their hands on it. 4 Clutches, 2 6spd trannys, a drive shaft, a rear end and rear suspension is normal to have to replace in a truck with less than 20k miles :rolleyes: Especially when they dont tighten down the bolts that hold the center carrier bearing up and it drops down doing 75mph on the highway and twists the drive shaft into a pretzel and tweaks every other bearing/shaft in the entire truck. All of the problems came after that happened from them having to replace the clutch because the disk was defective from the factory and blew apart at 4k miles :eek:
    I really feed bad for the poor bastard that got stuck with that truck after i traded it in for a different one that they hadn't touched
  7. Aug 20, 2012 at 12:40 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    x2 for Dartmouth
    I had an airbag light i brought to them to diagnose, they couldn't figure it out so they gave me a "complimentary" alignment. They gave me the graph and caster was greyed out. I asked and they told me caster can't be adjusted on my truck. Psh and i had just had my alignment done a few weeks earlier. so all they did for me was mess up my alignment and not do anything about my airbag light. ( which i later fixed myself after finding i could read the codes by jumping terminals on the obd2 port )
  8. Aug 20, 2012 at 6:11 PM
    white91formula
    Boston, MA
    05 6speed TRD OR
    They were the ones who originally fucked the truck up, RTE 44 only made it worse but Dartmouth was by far the worst
  9. Aug 25, 2012 at 6:55 PM
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    I work with them a little when I started shopping for my Taco but I ended up at Herb Chambers in Auburn--they gave me the $ I was looking for on my '03 Ram 2500 and when they messed up and got me a TX instead of a TX Pro, they swapped in the stainless exhaust gratis. So far so good on their service as well. I trust Chambers and Harr the most in central MA.
