mA draw w/ truck turned off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maybeme, Dec 23, 2019.
  1. Dec 23, 2019 at 7:22 PM
    Bishop84
    Bishop84 Well-Known Member
    We lock doors, hide key, then slip meter in without disrupting. I usually use a vice grip with my leads and ensure I get a clean reading.
    Disconnecting the battery, then inline through meter does wake the meter up.
    There is no radio code. Worst case scenario you have to reinitialize the power window.
    davidstacoma likes this.
  2. Dec 23, 2019 at 7:35 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Excellent method, I’ve done that in control systems testing but didn’t think of it, thanks!
  3. Dec 23, 2019 at 8:03 PM
    maybeme
    maybeme [OP] Well-Known Member
    Hmm - mine has been at 0.25 for about an hour now. Bishop84 said 2 hours - so I will wait at least that long.
    I will report after a few hours....
  4. Dec 23, 2019 at 9:30 PM
    maybeme
    Well....kudos to Bishop84: after 2 or so hours the current dropped from 0.25 A to 0.02 A. In other words - I really just have a defunct battery. I want the dealer to replace it...but I already bought aX2Power AGM 24F to replace the factory one. Don't want to take the risk of getting stranded....
    I will still keep the appointment, as I want to make sure that the charging circuit is up to par.
    Thanks everyone!
    Bernie
    Skydvrr and davidstacoma like this.
  5. Dec 23, 2019 at 9:37 PM
    Bishop84
    I prefer a battery to fail than a gremlin causing a drain. Some are horrible bastards to fix.
    Glad its sorted out!
    AKGSD and davidstacoma like this.
  6. Dec 23, 2019 at 10:12 PM
    davidstacoma
    David
    NC
    Good news, glad you’ve figured it out, and good advice from Bishop84. I too have learned a lot here.
  7. Dec 23, 2019 at 10:32 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    And you need to keep that new AGM maintained properly.
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    xxTacocaTxx likes this.
  8. Dec 24, 2019 at 12:51 AM
    caribe makaira
    Caribbean, Puerto Rico
  9. Dec 24, 2019 at 10:56 PM
    maybeme
  10. Dec 25, 2019 at 8:19 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    AGM battery and cold weather = never again for me
  11. Dec 25, 2019 at 8:08 PM
    maybeme
    Are AGM batteries worse in the cold than regular lead acid batteries?
  12. Dec 25, 2019 at 11:01 PM
    buffalkill
    buffalkill Member
    Roseville, Ca
    2017 DCSB OR
    AGM has a slight advantage over flooded when it comes to standard operating temperature range, not speaking from personal experience. You shouldn’t be second guessing your choice of battery, a lot of people run this battery without boosting voltage, should be fine as long as it’s a daily driver. Regular charging will certainly help, they recommend a charger capable of 7 amps or greater
  13. Dec 26, 2019 at 12:39 PM
    maybeme
    Thanks - appreciate the feedback!!
  14. Dec 26, 2019 at 12:47 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Drain the OEM to like 6v and get it tested, install the AGM. Go through Toyota online and tell em it left u stranded. They'll reimburse u the price of OEM.
  15. Dec 26, 2019 at 1:55 PM
    #35
    maybeme
    You mean get it tested by Toyota? They did that once already...
  16. Dec 26, 2019 at 2:00 PM
    #36
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I think what he is suggesting it get it independently tested after draining it down, then go go online and tell Toyota the battery left you stranded somewhere.
    xxTacocaTxx and Skydvrr like this.
  17. Dec 26, 2019 at 2:04 PM
    #37
    Skydvrr
    Nick
    YMH
    Black '17 OR
    What @Speedfreak said. Drain it to kill it good and proper, then go through Toyota online
    Speedfreak likes this.
  18. Dec 26, 2019 at 3:14 PM
    #38
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Ford’s spec was 50 milliamps for allowable parasitic draw.
    and you’re going to need to let it sit for 45 minutes to an hour for all the modules and network chatter to shut down - if you want to access anything in cab during testing, you’d better grab a screwdriver and latch the door “shut” beforehand so you can get in it without waking anything up
    - and you’ll have to trick the hood ajar switch too
  19. Dec 29, 2019 at 9:21 AM
    #39
    maybeme
    Lol - I actually don't have to fake it...my battery really struggles after sitting for a couple of days (which doesn't happen all that often). Yesterday evening I drove for about two hours and the no-load battery voltage this morning (at 28 Fahrenheit now and maybe 15 in the middle of the night) is 11.97 V.
    I'm assuming at least one hour of driving per day should maintain the charge, right? Also, for those who have done it - how do you start the process of trying to get Toyota to cover the battery...call them?
  20. Dec 29, 2019 at 9:37 AM
    #40
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Just go online and get their email. Fire one off and let them figure out which department u need.
