Machine gun sound???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Feb 29, 2020.
  1. Feb 29, 2020 at 10:52 AM
    vtdog
    vtdog Well-Known Member
    NH
    I had a Chevy as a work car. Exact same sound. It was from damper/blender door getting stuck. Motor would try to move and door would "snap" back making that sound. Chevy had a TSB about it, but with Tacoma, might be dead rodent blocking travel
    wilcam47 and Rexfordian13 like this.
  2. Feb 29, 2020 at 10:53 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Toyota says that’s normal. Chevrolet says we’ll fix it one day.
  3. Feb 29, 2020 at 6:05 PM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    A wider picture would help everyone to see where this connector is. Tech pictures should ALWAYS begin with a wide shot, then a close up of the part in question.
  4. Feb 29, 2020 at 7:38 PM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    I would wager it's that relay, whatever it is for, I would assume HVAC but I don't feel like looking it up. It's either getting signaled to cycle, or losing power/ground constantly. I would guess the latter. Pop the connector off, check the ground and power. When those come up normal, check the ohms, when that comes up normal, run a voltage drop test.
  5. Feb 29, 2020 at 7:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here are the locations of the three servos.
    It looks like that it is one of them in the picture. If so the topmost one is a pain in the ass. The other two not too bad.
    Looking at the picture it seems to be the Air Mix Servo Motor.
    Rexfordian13 and TnShooter like this.
  6. Feb 29, 2020 at 7:40 PM
    captaintofuburger
    You are always damn quick on point with schematics and layouts. Where are you grabbing those from? Alldata/Mitchell comes up short on me too often.
  7. Feb 29, 2020 at 7:42 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Have them on the hard drive of my computer...
    I have a few on my media directory here also.
    6 gearT444E and TnShooter like this.
  8. Mar 1, 2020 at 8:02 AM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    Yes, It is the Air Mix control as you pointed out.
    This is what I was going to get https://www.amazon.com/ACDelco-15-7...ds=ACDELCO+Part#1573513&qid=1583076364&sr=8-2
    It seems to fit a few different vehicles. Does it look right?
    Thanks again for your help
    Rexfordian13 likes this.
  9. Mar 1, 2020 at 5:01 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This should be what you need. Servo, Mode Control Servo 87106-04050.
    Also:
    ACDELCO Part#1573513 (1572858, 15842338, 52494371)
    DORMAN Part#604109 (autozone and o'reilly carry this one)
    STANDARD MOTOR PRODUCTS Part#F04007
    Blockhead likes this.
