machining debris found in rear axle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by devinzz1, Aug 25, 2024.
  1. Aug 25, 2024 at 7:43 PM
    devinzz1
    devinzz1 [OP] Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    the flake of metal isnt super stuck to that magnet and has some decent surface area. at 60+ i wonder if theres enough force from the oil to pull it from the magnet and start circulating in the oil again. theres no noise from this diff and i plan to pull and put 5.29s in anyways so not super concerned about it
  2. Aug 25, 2024 at 8:03 PM
    Bill400
    Bill400 Well-Known Member
    Bill
    2023/7170 (SR5, V6, DBL Cab, 4X2) Red, Advanced Tech Pkg
    OEM BSM/CTA retrofit complete
    Thanks for the post.
    Did the "break-in" oil change.
    Now for the differential grease swap, hunting for "buried treasure".
  3. Aug 25, 2024 at 8:31 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Try a plug with stronger magnet? I use this one: https://www.summitracing.com/parts/tgi-140032-1-kit
  4. Aug 25, 2024 at 11:39 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Look at 4:32 of the video you quoted.
    The drain plug is in a recess in the bottom of that housing, away from the main flow of oil. I highly doubt anything on that magnet gets disturbed, by design.
    This is a bunch of concern about nothing.
    OffRoadWannabe and koditten like this.
  5. Aug 26, 2024 at 4:50 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I could be wrong but I thought the entire rear end is manufactured by Hino who supplies Toyota heavy and light trucks. Toyota doesn't make these in house.
    I'm also pretty sure those casing bits would get obliterated by the much harder gears in the diff if the magnet didn't get them first. No "extras" like that when I did my OR a couple months ago though.
    Chew, ace_10 and jmneill like this.
  6. Aug 26, 2024 at 5:25 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Yep, they'd just get turned into glitter..
    Non-issue.
    Chew, Smacky2020[QUOTED] and koditten like this.
